No current reading with Cube Orange, working on Ardupilot
Hey,
I’ve just made the switch to PX4 from Ardupilot, but now the power module is constantly reading 0 current (voltage works fine). I’ve briefly switched back to Ardupilot to confirm it’s not hardware related, and there 0.3A is read at idle (which my external Watt Meter ~ also reads).
I’ve also check the raw MavLink messages which also reads 0.
I’m using a Cube Orange with the standard carrier board with the included power brick, which I’ve even swapped out without changes. I’ve connected it to both POWER ports of the pixhawk, with no change.
Here are my battery params:
Screenshot 2022-05-20 134631
Do I have to set the BAT2_I_CHANNEL param? I haven’t really found documentation for that parameter.
Okay,
It indeed was the BAT_I_CHANNEL. Apparently for ADS-B IN Carrier Boards the automatic detection is wrong, for POWER1 you need to manually set BAT1_I_CHANNEL to 4 and for POWER2 BAT2_I_CHANNEL to 15.
What I still find weird are the calibrated voltage per amp values. For POWER1 it’s 6 A/V and POWER2 over 110 A/V. I think I never saw such a big difference between the connectors. But it works, at least :smiley:
I have a cuav v5 autopilot. How can I learn Bat1_I_channel parameter?
Could you give me the source of this information? it just works
I think it was mentioned in some other forum post. I couldn’t find it doing a quick search.
Well I had this problem and the answer has solved my problem before. But for the new batch of Cube Oranges I got the solution didn’t worked. I am trying to find out which ADC channel is for the power 1 current reading input.
Thanks for sorting this all out. I couldn’t find this documentation anywhere.
I understand this is a very old post, but I’ve encountered exactly the same issue with a 15.2 build on the Orange+ on a mini board. Setting it to 4 does not appear to be the correct value, but I will try injecting a 1-2v signal to that pin and see if I can locate the correct ADC.
Is there a way to view the ADC values live to find it efficiently?
Yes this is a very old post, and I did answered to it. Yet again I still come into this problem. Did you found out the correct current ADC pin?
Hello, same problem here - reads only —.—
