No answers for Beginner 1
Hello everyone. What am I doing wrong that I’m not getting any answers? Have a nice day. Beginner 1
Dear sir,
I have been trying to get answers for a year, the community support is atrocious. I have read about the systems quite a bit, and if you spend enough time there you may find the answers you need, maybe. As far as i can tell it is a dig for yourself program. unless you can make some friends here that will take you under their wing. Doc
Been there.
First - try to translate your posts to English (as you did here). Lots of people are too lazy to translate themselves. Plus, if it’s clear that the readers will have to translate your post, to me it seems lazy not to translate it yourself (you can keep the original language as well).
Second - include detailed info about your issue. For example: “I tried everything and it doesn’t work” is meaningless, since we have no idea what was actually done. Add screenshots, firmware and software revisions, configurations, hardware models, everything that might have the slightest connection to the issue.
Third - as @Docslabs said - you’ll find most answers in the documentation and\or code. Go to PX4 doc and try looking for keywords that might be related, you can also use Google since it also looks within PX4 documentation and this forum.
Dear dotanAtTrim:
Regarding the first paragraph: Google translations are usually bad, sometimes incomprehensible. This is something I have been struggling with ever since I started working with autonomous flight (3 ½ years). Regarding the BSP FrSky manual. Some things in English are not entirely understandable, even for someone who can speak English.
Regarding the second paragraph: If I followed your advice, it would fill a book that no one would read.
Regarding the third paragraph: Enter “qgc: COM_RC does not exist”. The answers you found are as helpful as any.
I am currently looking for why the line “MAV_CMD_COMPONENT_ARM_DISARM command failed” is missing in the QGC parameters. Digital Air Speed ​​Sensor - MS5525DSO is in the parameters, but only works with I2C-MS4525DO.
My components: RC FrSky X20S, Archer R8 Pro receiver, Holybro Pixhawk 6C, Holybro M10 GPS module, Qgroundcontrol, Mission Planner and Digital Air Speed ​​Sensor – MS5525DSO. Best regards Beginner1
Dear Sir Doc! You are so right. Because of this, I wonder what good such forums are at all, since you spend a lot of time on them and still don’t come to a solution. Motto: Help yourself and God will help you. Best wishes, Beginner1
Hello everyone,
I am trying to run custom-example of Qgcs. Till now I have excluded the changed files also added custom file in res folder under custom folder and added those in custom.qrc and the updateqrc.py runs successfully but when I clean build (option in qt creator )build it again by the hammer icon changes as not deflected. please let me know if there is anything i am missing.
@prabhat_srivastava
Please post your question/problem only once. No point in posting it multiple times as you have done and expecting a faster response. - Those who are on here willing to help don’t won’t to have their time wasted by reading through multiple yet same posts.
Thanks. Best wishes. there are a couple of other options available to utilize, maybe check into them. Regards, Doc. (check community support first, …)
If only I knew what they meant.
I understand the frustration, there are lots of questions that go unanswered, and that can be because of a lot of reasons ranging from:
  • your post doesn’t contain a question / your question wasn’t clear
  • you didn’t explain enough of your setup
  • you are asking in the wrong place
  • there’s no one who has encountered your issue before
  • diving into your issue takes more time than volunteers have to properly engage
  • etc…
You have to remember this is an open-source project that is community-driven, and everyone here is volunteering their time.
Things to try next time:
  • See the above list and see if you can improve the quality of your posts
  • Join Discord and post a link to your issue explaining your situation Dronecode Foundation
  • Join one of the weekly Q&A calls, we have been running those for more than a decade, they are free, and public here’s the calendar Dronecode Calendar — Dronecode Foundation
Thank you for the detailed answer, Mr. rroche!
This is all new territory for me: the problems I have, posting and also the language: English communication is only possible via Google, which is bad, but better than nothing.
If you have put together numerous components according to instructions that you painstakingly search for on the Internet and the whole thing still doesn’t work, it becomes difficult.
Everywhere you read how to do it, but nowhere does it say what you can do if it doesn’t work.
