Thank you.
I watched your video how to upgrade the firmware, well done !
How to buy it?
Anyway I didn’t see any manual that explain the air unit , how to connect the port UART SBUS ?
Is there a diagram of the air unit ?
Which kind of cables inside the box ?
@bys_1123 In the above comments you write, “You can install any non-Google Mobile Services dependent Android APP on it, most of GCS APP is no problem.”
Does this include Mission Planner for windows?
Thanks!
Yes but you still need an SSL cert on your web site.
No, it’s runing Android OS, not windows.
hello , its use V5+ autopilot
can i use it with pixhawk 2.1 ?
and how
Do you have any update on the CE certification?
can i ask a few questions about the h16 and h16 pro they say h16 is for 10 kilometers and the h16 pro is for 20-30 but hardware for video are the same in both corret ?
Ethernet port is a nice feature.
But IP cameras are not accessible from devices, laptops connected to the H16 hotspot. The air unit as well as the MIPI camera can be accessed. But not the IP cameras connected to the ETH port of the air unit.
Why?? How can I make them accessible?
Hi @bys_1123 , Thanks for the description and explanation
this looks very interesting and useful.
could you pls answer a question?
Does it support RTK? what RTK does it support?
