My name is Abel, from Texas USA. I had a problem recently when I built a new Drone and flashed PX4 in the Pixhawk 2.1 Cube.
This is very strange, the drone has a quite high CG. When the drone tooks off, it hovers but with oscillations. The oscillations are back and forward around the axis that passes trough the front left and the rear right arms.
However, if I attach a payload below my drone, the oscillations almost disappear and the drone flights way better.
I tried to flash Ardupilot, and It flies perfectly with this firmware by default. However I prefer PX4 so I would like to solve this stability problems and keep using PX4 for the development of this drone.
I did not perform any change in the settings. They were the ones by default. With other drones that I built before it was working perfectly. But with this one it does not. I calibrated the sensors and that is all. What details do you exactly need?
Yes, I mounted it on 4 anti-vibration pillars, the behavior is still the same, flies good with ardupilot, and PX4 with payload. But empty with PX4 oscilations
I have the Pixhawk cube blue (US made), also I tried before other cubes, I thought that a better quality cube would help (that is why I got the blue finally), but it does not.
