Mission Planner is made for ArduPilot. Unfortunately, the mission upload protocol (using of mavlink) is slightly different between PX4 and ArduPilot, and in this case that’s preventing the successful transfer, unfortunately.
Hey Julian,
Thanks for your answer, i have two problèm with qgc (maybe due to my unknoledge)
1st i need kml overlay, i means juste view the polygones on the maps with not just one polygone.
2nd i need thé drone stay in thé bundary of the polygone during survey. For exemple if i make a polygone with an “u” shape thé grid will cross thé bondary.
1st I don’t think that’s supported. You have to add that to QGC yourself, convince someone to help you do it, or find a consultant too add it for you.
2nd You could try to add several surveys after each other as you can have several per mission. Or just create polygon in a way how you need it. I’m not sure if polygons are possible for surveys, I’d have to try it out.
I Can draw a polygone for survey, but the route doesnt stay in thé bundary of thé polygone, i think it’s because it’s faster, but when its tree on thé side of thé bondary its not good
