Hello, I have set up my lidar lite-v3 wiring correctly and have followed https://docs.px4.io/v1.9.0/en/sensor/lidar_lite.html in order to try to set it up in PWM mode in PX4. I enabled the rangefinder/port is enabled using [SENS_EN_LL40LS] - set to 1 for PWM but I still cant see it connected and see any data using analyze. The document said that my driver ( drivers/ll40ls ) may be missing but I do not know where to get it and how to add it to the board configuration. Is this the problem and how do I go about doing this?
I dont understand how the SD card is working and I am wondering if that is the ploblem. I have tried it with the micro SD in the pixhawk and then my computer and both things give the same result. I dont know what to do next
I suppose you have done the bootloader update then and you really have a v2, so you need to either upgrade your hardware to something newer. Or you need to build PX4 yourself with what drivers and modules you specifically need.
I can’t complete that step because the reboot resets the SYS_BL_UPDATE command every time I try to reboot it in step 4(“Reboot (disconnect/reconnect the board). The bootloader update will only take a few seconds.”) and there is no new hardware automatically detected.
Step 3 before reboot :
