Impossible to select an airframe
Hi everyone,
I am currently facing an issue that I have never had before. The problem appears when I try to select an airframe for my Intel AERO Drone. In reality I have two problems.
The first one is that QGroundControl (v.3.4.0) does not offer me the possibility to select the right airframe for my drone so I have to select one I think is the closest one of my real airframe. It is weird because I work with an other student who is able to select the right Airframe. The only difference between us is that he installed QGC on Windows whereas I installed it on Linux Ubuntu. Here is a picture of which airframes I can choose.
The second one is that QGC seems not to save the airframe I select. That is what my interface looks like after I selected a Generic Quadrotor X airframe.
It is a bit annoying since I can not do the other calibration properly because QGroundControl reacts like I never told it which airframe I am using.Then it does not know if it is connected to a Quadrotor or a plane for example.
Here are the full informations of the versions I am using :
The firmware is Px4.
BIOS_VERSION = AERO-01.00.13
OS_VERSION = Poky Aero (Intel Aero Linux Distro) 1.6.1 (pyro)"
AIRMAP_VERSION = 0xc2
AeroFC firmware version = 1.6.5
QGroundControl 3.4.0
~Paul
@Pauloledes, you might get a faster response from the developers if you submit this as an issue in github.
@Al_B Thanks I will do that !
