I’m building a quadcopter using the PX4 kit and I accidentally dropped a tiny bit of hot solder in the I/O-PMW-in port of the Pixhawk 4 Power Module (PM07) board (http://www.holybro.com/manual/PM07-Quick-Start-Guide.pdf). Although I tried cleaning it as best as I could, I believe this is causing a connection problem with the ESC’s which are connected using M1-M4. The PX4 is connected to the PDB through the I/O PWM OUT ↔ I/O-PMW-in connection.
I was wondering if I could program the PX4 to send the signals to the motors using the FMU PWM OUT ↔ FMU-PWM-in connection, and have the ESC’s connected to the FMU-PWM-out ports on the PDB.
Here are the pinouts for the PX4: http://www.holybro.com/manual/Pixhawk4-Pinouts.pdf
Thanks in advance for any assistance you can provide!
