Hi, I have a Here3+ and want to connect it to my Cube Orange running PX4. The Here3+ is connected via CAN but I don’t get any satellites even if I am standing outside, and my here+ RTK ground station is getting 18 Satellites or more. On the other hand the Compass is working correctly. I also get MAVLink messages from the GPS but with Satelites 0 and no position. The parameters in QGC show: GPS Count: 0, GPS Lock: None, HDOP 100.0, VDOP: 100.0 Course Over Ground 0.0. can anyone help ?
uavcan_mag adding channel for topic sensor_mag node 125...
uavcan_mag channel 125 instance 1 ok
ERROR [uavcan] GetSet error during param count
uavcan_gnss adding channel for topic sensor_gps node 125...
uavcan_gnss node 125 instance 0 ok
uavcan_gnss node 125 topic sensor_gps instance 0 ok
WARN [uavcan] GNSS Fix2 msg detected for ch 0; disabling Fix msg for this node
WARN [health_and_arming_checks] Preflight Fail: High Accelerometer Bias
