GeoFence transfer failed. Error: Mission read failed, maximum retries exceeded
Hello everyone, there is a problem,
If the geofence is set in PX4(through QGC), the QGC would show the message “GeoFence transfer failed. Error: Mission read failed, maximum retries exceeded.” during the linking between QGC and PX4. Does anyone has the idea about this problem?
QGC: v4.3.0(83d9a3c), Andorid(Galaxy Tab Active3, Android V13)
PX4: Stable Release v1.14.0(83d9a3c), “Cube Orange plus” with “Airbot Mini carrier board”
Can you try latest v1.14.2. I know that’s not flashed by default in QGC but maybe you can build it on your own?
This has been fixed a while ago:
And backported to v1.14:
I tried the latest v1.14.2, the problem solved, thank you so much.
I am using the 1.15.0 version and the geofence set but I am still facing these issues when I try to do HITL in jmavsim
