Fail to set Airframe - Rover : "Aion Roboticks R1 UGB"
QGC Version: v4.4.3
Flight Controller (FC): Pixhawk4 - v1.15.2
I’m trying to set the airframe to Rover - Aion Robotics R1 UGV in QGroundControl (QGC).
However, after setting it up and clicking Apply and Reset, the settings are not saved, and QGC shows an unconfigured state.
Even when I manually set Parameters → SYS_AUTOSTART to 50003, the same issue occurs after applying and resetting.
I need help resolving this issue. If anyone has experienced a similar problem or knows a solution, please let me know.
I tested this on CUAV X7pro running firmware version v1.15.2, but the problem is same.
Hello!
You can refer to this one to flash your board with a specific rover firmware. Because it is experimental in PX4, so you can’t use the default firmware.
Flashing the Rover Build
I think for your case, for Pixhawk4, you can use px4_fmu-v5_rover.
I tried it previously with my Pixhawk6c and Pixhawk6x, and it’s working just fine for version 1.15.2, with airframe aion robotics r1, by setting the SYS_AUTOSTART to “50003”
Hope it works ^^
Thank you! I’ll try it the way you suggested!
Yeah having the same issue. I tried their “solution” but it does not work, it just doesn’t save the configuration even with changing the parameters manually.
you need to build the firmware manually, not from the qground
