Unable to Setup Generic Ground Vehicle Airframe
QGC version 4.4.0
I am unable to get the Generic Ground Vehicle (Ackermann) airframe to apply to pixhawk 6x (1.15.0)
Each time I attempt to apply the airframe change, the device restarts as expected but returns with “Airframe is not set” the next time I open the vehicle setup menu.
I have tested and am able to apply the generic quadcopter airframe but upon trying the ground vehicle (the one I need) I am returned back to no set airframe.
Edit: Appears i hadn’t dug deep enough into documentation and needed to flash the ackermann rover build over to the pixhawk.
I encountered the same problem, how do you actually produce a new version for the ROVER?
