I am using rox foxy on an ubuntu 20.4 machine
When I call this command commander takeoff, I get the following but the drone does not move atall
pxh> INFO [tone_alarm] home set
pxh> cINFO [tone_alarm] notify negative
pxh> commander takeoff
pxh> INFO [commander] Armed by internal command
INFO [navigator] Using minimum takeoff altitude: 2.50 m
INFO [commander] Takeoff detected
WARN [commander] Failsafe enabled: no datalink
INFO [commander] Failsafe mode activated
INFO [tone_alarm] battery warning (fast)
INFO [navigator] RTL HOME activated
INFO [navigator] RTL: landing at home position.
INFO [navigator] RTL: climb to 489 m (1 m above destination)
INFO [commander] Failsafe mode deactivated
INFO [navigator] RTL: return at 489 m (1 m above destination)
INFO [navigator] RTL: land at destination
INFO [commander] Landing detected
INFO [commander] Disarmed by landing
INFO [logger] closed logfile, bytes written: 3975567
It seems that the EKF did not initialize. When running the make px4_sitl_rtps gazebo, the output is ass follows:
[0/4] Performing build step for 'sitl_gazebo'
ninja: no work to do.
[3/4] cd /home/stevedan/project_001/navity/control_mo.../mission_controller/PX4-Autopilot/build/px4_sitl_rtps
SITL ARGS
sitl_bin: /home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/build/px4_sitl_rtps/bin/px4
debugger: none
program: gazebo
model: none
world: none
src_path: /home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot
build_path: /home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/build/px4_sitl_rtps
GAZEBO_PLUGIN_PATH :/home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/build/px4_sitl_rtps/build_gazebo
GAZEBO_MODEL_PATH /home/stevedan/gazebo_models/models::/home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/Tools/sitl_gazebo/models
LD_LIBRARY_PATH /home/stevedan/project_001/navity/navity_ws/install/px4_ros_com/lib:/home/stevedan/project_001/navity/navity_ws/install/px4_msgs/lib:/home/stevedan/ros2_foxy/ros2-linux/opt/yaml_cpp_vendor/lib:/home/stevedan/ros2_foxy/ros2-linux/opt/rviz_ogre_vendor/lib:/home/stevedan/ros2_foxy/ros2-linux/lib:/usr/lib/x86_64-linux-gnu/gazebo-11/plugins:/opt/ros/foxy/opt/yaml_cpp_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:/opt/ros/noetic/lib:/home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/build/px4_sitl_rtps/build_gazebo
empty world, setting empty.world as default
Using: /home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/Tools/sitl_gazebo/models/iris/iris.sdf
gzserver not ready yet, trying again!
SITL COMMAND: "/home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/build/px4_sitl_rtps/bin/px4" "/home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/build/px4_sitl_rtps"/etc -s etc/init.d-posix/rcS -t "/home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot"/test_data
Creating symlink /home/stevedan/project_001/navity/control_module/mission_controller/PX4-Autopilot/build/px4_sitl_rtps/
_____ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [init] found model autostart file as SYS_AUTOSTART=10016
INFO [param] selected parameter default file eeprom/parameters_10016
INFO [parameters] BSON document size 333 bytes, decoded 333 bytes (INT32:14, FLOAT:3)
[param] Loaded: eeprom/parameters_10016
INFO [dataman] data manager file './dataman' size is 7866640 bytes
PX4 SIM HOST: localhost
INFO [simulator] Waiting for simulator to accept connection on TCP port 4560
INFO [simulator] Simulator connected on TCP port 4560.
INFO [commander] LED: open /dev/led0 failed (22)
INFO [micrortps_client] UDP transport: ip address: 127.0.0.1; recv port: 2019; send port: 2020
INFO [micrortps_client] UDP transport: Trying to connect...
INFO [micrortps_client] UDP transport: Connected to server!
INFO [init] Mixer: etc/mixers/quad_w.main.mix on /dev/pwm_output0
INFO [init] setting PWM_AUX_OUT none
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 18570 remote port 14550
Gazebo multi-robot simulator, version 11.10.1
Copyright (C) 2012 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.0.101
INFO [mavlink] mode: Onboard, data rate: 4000 B/s on udp port 14280 remote port 14030
INFO [mavlink] mode: Gimbal, data rate: 400000 B/s on udp port 13030 remote port 13280
INFO [logger] [logger] ./log/2022-03-14/22_32_52.ulg
INFO [logger] Opened full log file: ./log/2022-03-14/22_32_52.ulg
INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
pxh> [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
ERROR [uORB] estimator_innovation_variances advertise failed (5)
ERROR [uORB] estimator_innovations advertise failed (5)
ERROR [uORB] estimator_optical_flow_vel advertise failed (5)
ERROR [uORB] estimator_sensor_bias advertise failed (5)
ERROR [uORB] estimator_states advertise failed (5)
ERROR [uORB] estimator_status_flags advertise failed (5)
ERROR [uORB] estimator_status advertise failed (5)
ERROR [uORB] estimator_visual_odometry_aligned advertise failed (5)
ERROR [uORB] yaw_estimator_status advertise failed (5)
ERROR [uORB] estimator_global_position advertise failed (5)
ERROR [uORB] estimator_local_position advertise failed (5)
ERROR [uORB] estimator_attitude advertise failed (5)
ERROR [ekf2] publication instance problem: -1 att: -1 lpos: -1 gpos: -1
ERROR [ekf2] alloc and init failed imu: 0 mag:1
ERROR [uORB] estimator_odometry advertise failed (5)
ERROR [uORB] estimator_wind advertise failed (5)
ERROR [uORB] ekf2_timestamps advertise failed (5)
ERROR [uORB] estimator_baro_bias advertise failed (5)
ERROR [uORB] estimator_event_flags advertise failed (5)
ERROR [uORB] estimator_gps_status advertise failed (5)
ERROR [uORB] estimator_innovation_test_ratios advertise failed (5)
ERROR [ekf2] alloc and init failed imu: 0 mag:0
