I would like to convert the waypoints in the .plan JSON file generated from QGC to setpoints to control my drone in the offboard mode.
The reason why I am doing this is that I would like to implement a collision avoidance algorithm and to perform the avoidance maneuver, I will change setpoints that are sent by ROS2 in the middle of the flight.
Is there a guide on how to map the JSON file to offboard setpoint?
Also, do you think it would be better if I avoid the offboard mode and modify the mission waypoints directly in the middle of a flight? if yes, is that possible with the current state of px4_ros_com?
The offboard obstacle avoidance here sends local coordinated. However, I am trying to send the global coordinates (LLA) similar to the waypoints in the QGC mission plan file. I tried to send the latitude/longitude/altitude in a position_setpoint message from micrortps_agent to micrortps_client but it didn’t move the drone. I wrote another issue here
