I am using ROS2 foxy/px4/fastRTPS.
I tried the offboard_control example as specified here. After adding some minor modifications to synchronize the time stamp as specified in this thread
It works fine with the local coordinated. However, I would like to operate it using global coordinates so I set it as follows:
msg.current.lat = 47.3977511; // my current latitude
msg.current.lon = 8.5456072; // my current longitude
msg.current.alt = 499.0; // 10m above my current AMSL altitude
I also set
msg.current.x = 0.0;
The drone is armed successfully but it doesn’t move to the specified altitude.
Could somebody assist me on how to configure the global frame of the offboard mode?
My ROS code is:
* @brief Offboard control example
* @file offboard_control.cpp
* @addtogroup examples
* @author Mickey Cowden <info@cowden.tech>
* @author Nuno Marques <nuno.marques@dronesolutions.io>
#include <px4_msgs/msg/offboard_control_mode.hpp>
#include <px4_msgs/msg/position_setpoint_triplet.hpp>
#include <px4_msgs/msg/timesync.hpp>
#include <px4_msgs/msg/vehicle_command.hpp>
#include <px4_msgs/msg/vehicle_control_mode.hpp>
#include <rclcpp/rclcpp.hpp>
#include <chrono>
#include <iostream>
using namespace std::chrono;
using namespace std::chrono_literals;
using namespace px4_msgs::msg;
class OffboardControl : public rclcpp::Node
public:
OffboardControl() : Node("offboard_control")
#ifdef ROS_DEFAULT_API
offboard_control_mode_publisher_ =
this->create_publisher<OffboardControlMode>("OffboardControlMode_PubSubTopic", 10);
position_setpoint_triplet_publisher_ =
this->create_publisher<PositionSetpointTriplet>("PositionSetpointTriplet_PubSubTopic", 10);
vehicle_command_publisher_ = this->create_publisher<VehicleCommand>("VehicleCommand_PubSubTopic", 10);
#else
this->create_publisher<OffboardControlMode>("OffboardControlMode_PubSubTopic");
this->create_publisher<PositionSetpointTriplet>("PositionSetpointTriplet_PubSubTopic");
vehicle_command_publisher_ = this->create_publisher<VehicleCommand>("VehicleCommand_PubSubTopic");
#endif
timesync_sub = this->create_subscription<px4_msgs::msg::Timesync>("Timesync_PubSubTopic",
10,
[this](const px4_msgs::msg::Timesync::UniquePtr msg) {
timestamp = msg->timestamp;
offboard_setpoint_counter_ = 0;
auto timer_callback = [this]() -> void {
// define common timestamp
// auto timestamp = time_point_cast<microseconds>(steady_clock::now()).time_since_epoch().count();
if (offboard_setpoint_counter_ == 100)
// Change to Offboard mode after 100 setpoints
this->publish_vehicle_command(VehicleCommand::VEHICLE_CMD_DO_SET_MODE, timestamp, 1, 6);
// Arm the vehicle
this->arm();
// offboard_control_mode needs to be paired with position_setpoint_triplet
publish_offboard_control_mode(timestamp);
publish_position_setpoint_triplet(timestamp);
// stop the counter after reaching 100
if (offboard_setpoint_counter_ < 101)
offboard_setpoint_counter_++;
timer_ = this->create_wall_timer(10ms, timer_callback);
void arm() const;
void disarm() const;
private:
unsigned long long timestamp;
rclcpp::TimerBase::SharedPtr timer_;
rclcpp::Publisher<OffboardControlMode>::SharedPtr offboard_control_mode_publisher_;
rclcpp::Publisher<PositionSetpointTriplet>::SharedPtr position_setpoint_triplet_publisher_;
rclcpp::Publisher<VehicleCommand>::SharedPtr vehicle_command_publisher_;
rclcpp::Subscription<px4_msgs::msg::Timesync>::SharedPtr timesync_sub;
uint64_t offboard_setpoint_counter_; //!< counter for the number of setpoints sent
void publish_offboard_control_mode(const long int ×tamp) const;
void publish_position_setpoint_triplet(const long int ×tamp) const;
void publish_vehicle_command(uint16_t command, const long int ×tamp, float param1 = 0.0,
float param2 = 0.0) const;
* @brief Send a command to Arm the vehicle
void OffboardControl::arm() const
publish_vehicle_command(VehicleCommand::VEHICLE_CMD_COMPONENT_ARM_DISARM, timestamp, 1.0);
RCLCPP_INFO(this->get_logger(), "Arm command send");
* @brief Send a command to Disarm the vehicle
void OffboardControl::disarm() const
publish_vehicle_command(VehicleCommand::VEHICLE_CMD_COMPONENT_ARM_DISARM, timestamp, 0.0);
RCLCPP_INFO(this->get_logger(), "Disarm command send");
* @brief Publish the offboard control mode.
* For this example, only position and altitude controls are active.
* @param timestamp Timestamp of the setpoint triplet
void OffboardControl::publish_offboard_control_mode(const long int ×tamp) const
OffboardControlMode msg{};
msg.timestamp = timestamp;
msg.ignore_thrust = true;
msg.ignore_attitude = true;
msg.ignore_bodyrate_x = true;
msg.ignore_bodyrate_y = true;
msg.ignore_bodyrate_z = true;
msg.ignore_position = false;
msg.ignore_velocity = true;
msg.ignore_acceleration_force = true;
msg.ignore_alt_hold = true;
offboard_control_mode_publisher_->publish(msg);
* @brief Publish position setpoint triplets.
* For this example, it sends position setpoint triplets to make the
* vehicle hover at 5 meters.
void OffboardControl::publish_position_setpoint_triplet(const long int ×tamp) const
PositionSetpointTriplet msg{};
msg.current.timestamp = timestamp;
msg.current.type = PositionSetpoint::SETPOINT_TYPE_POSITION;
msg.current.y = 0.0;
msg.current.z = 0.0;
msg.current.lat = 47.3977514;
msg.current.lon = 8.5456071;
msg.current.yaw = 1.5707963268;
msg.current.cruising_speed = 2.0;
msg.current.position_valid = true;
msg.current.yaw_valid = true;
msg.current.alt_valid = true;
msg.current.valid = true;
position_setpoint_triplet_publisher_->publish(msg);
* @brief Publish vehicle commands
* @param command Command code (matches VehicleCommand and MAVLink MAV_CMD codes)
* @param timestamp Timestamp of the command
* @param param1 Command parameter 1
* @param param2 Command parameter 2
void OffboardControl::publish_vehicle_command(uint16_t command, const long int ×tamp, float param1,
float param2) const
VehicleCommand msg{};
msg.param1 = param1;
msg.param2 = param2;
msg.command = command;
msg.target_system = 1;
msg.target_component = 1;
msg.source_system = 1;
msg.source_component = 1;
msg.from_external = true;
vehicle_command_publisher_->publish(msg);
int main(int argc, char *argv[])
std::cout << "Starting offboard control node..." << std::endl;
setvbuf(stdout, NULL, _IONBF, BUFSIZ);
rclcpp::init(argc, argv);
rclcpp::spin(std::make_shared<OffboardControl>());
rclcpp::shutdown();
return 0;
