Accessing QGroundControl Mission Waypoints from PX4 for External Guidance Command
Hi everyone,
I’m working on a project where I use QGroundControl to upload missions in Mission mode, and I want to access the waypoints (mission items) directly from PX4, as I have a custom guidance algorithm running on a companion computer.
The idea is to:
  • Use QGC to define/upload waypoints
  • Read those waypoints inside PX4 (from MAVLink or internal mission storage)
  • Send them to my companion computer (via MAVLink or other interface) to process using my own guidance logic
My Questions:
  1. What is the best way to access the mission waypoints from PX4 firmware? Is there a uORB topic or API that I can tap into?
  2. Where in the PX4 source code is the mission data stored after uploading from QGC?
Details of the hardware:
Autopilot: Pixhawk 6x with firmware version v1.16.alpha
Companion computer: Raspberry Pi 4B running Ubuntu 24.04
Connected using an Ethernet cable
Hi here is my note:
Extract mission waypoints
In this tuto, I implement the code in examples/px4_simple_app.cpp for displaying waypoints created in QGC and send to vehicle. This example displays only the latitude waypoints.
1) change the file extension to .cpp and
 modif extern "C" __EXPORT int px4_simple_app_main(int argc, char *argv[]);
 to avoid error:unknown type name ‘namespace’ [https://stackoverflow.com/questions/13602249/how-to-fix-error-unknown-type-name-namespace]
2) includes :
#include <dataman_client/DatamanClient.hpp>
#include <navigator/navigator.h>
#include <uORB/topics/mission.h>
3) subscribe to mission topic :
/* subscribe to mission topic */
uORB::Subscription _mission_sub{ORB_ID(mission)};
4) code to extract wps :
* @brief Maximum time to wait for dataman loading
static constexpr hrt_abstime MAX_DATAMAN_LOAD_WAIT{500_ms};
if (_mission_sub.updated()) {
	mission_s new_mission;
	_mission_sub.update(&new_mission);
	PX4_INFO("new_mission.count: %d", (int)new_mission.count);
	DatamanCache _dataman_cache{"mission_dm_cache_miss", 10}; /**< Dataman cache of mission items*/
	for (int i = 0; i <= new_mission.count; i++) {
		mission_item_s next_position_mission_item;
		const dm_item_t mission_dataman_id = static_cast<dm_item_t>(new_mission.mission_dataman_id);
		bool success = _dataman_cache.loadWait(mission_dataman_id, i,
reinterpret_cast<uint8_t *>(&next_position_mission_item), sizeof(next_position_mission_item), MAX_DATAMAN_LOAD_WAIT);
		if (success) { // retrieve wps here
			PX4_INFO("Position lat %.6f\t", next_position_mission_item.lat);
5) add to CmakeLists.txt :
	DEPENDS
		dataman_client
6) select this px4_simple_app in boardconfig, compile with make px4_sitl gazebo. In the mavlink console call the app with px4_simple_app.
Hi psvs,
You can reference this page.
Thanks Loon_NG_fr, terrymao886,
I was able to find the corresponding file (mission.cpp) and update it in the PX4 firmware directly.
