Connecting SiYi MK32 Groundstation to PX4
I am struggling to get QGroundControl on the MK32 to recognize my flight controller. I have attempted to connect it through telemetry. The MK32 successfully connects to the ZT6 and SiYi link that I am using, video is working great. Unfortunately QGroundControl can’t find the vehicle.
I have also tried connecting it directly with a USB-C cable to no avail. When I connected it in the same way to an ardupilot flight controller, it worked just fine. I also connected my PX4 controller to QGroundControl on my PC with no issue.
I figured the issue might have come from the fact that the groundstation uses a modified version of QGroundControl for SiYi integration, so I installed the original apk, which didn’t work either.
I can’t think of many other options aside from re-flashing the firmware onto the flight controller, which I am wary to try. I haven’t been able to find much else of use in the manuals.
I hope you’ve already got this sorted out. But if not, sounds like you need to go into SIYI TX>Top Right Button (COM Link I believe)> change to USB COM. Exit and try QGC again.
