Connecting Pixhawk 4 with a camera
I have Pixhawk 4 and JJA-CM1200 FPV camera , is it possible to connect the camera directly to the flight controller ? And if yes, how ?
Or I have to use Raspberry Pi ?
Âżalguien sabe?
Creo que debes conectarlo al puerto UART
It depends on what you’re trying to do with the video; Save, transmit, or view.
Maybe the Pixhawk can take ADC input throught the header but you would have to code up the viewer/saver but maybe could be done through Mission Planner.
If you wanted to capture/save/play on a raspberry pi you could use an CVBS to USB (ADC) converter.
