I am doing a little different thing, here are the details:
1- PixHawk 4
2- Raspberry Pi 4
3- 4K Camera (Make & Model Not selected)
RPi = Raspberry Pi 4 (Single Board Computer)
PH = HolyBro PixHawk 4
I connected the RPi with PH using the Telemetry Port 2 of PH & Serial Port of RPi. Both get connected and I can operate the PH from the RPi. Everything is fine till this.
But the real problem which I had is: I want to connect a camera with my RPi so it can save the images on the Memory device connected with the RPi, but my camera will capture the images on the GPS locations which I set in the WayPoints while uploading the Mission on the PH.
I know there are AUX ports (AUX4-5 or AUX5-6) in the FMU PWM OUT, but how to use those or something like this, I am confused about the flow.
Please help me with the flow and the solution as well.
