I wanted to ask some questions about the connections to be made with Pixhawk 2.4.8 (sorry, but I’m new).
I have Pixhawk 2.4.8 and ELRS receiver.
Recently I have successfully paired them following the guide on the ELRS site Elrs guide, but it works only for ardupilot.
So i’m just struggling to find analog of SERIALx_PROTOCOL = 23 (RCIN) and
RSSI_TYPE = 3 settings in PX4
Thanks!
ELRS receiver communicate with FMU through CRSF protocol. PX4 does not support this protocol. So, in order to do this you need to include a CRSF to SBUS converter.
Short answer, yes it’s possible.
How to do it?
You need to set RC_CRSF_PRT_CFG parameter to the serial that you’re using. BUT You can’t use prebuilt PX4 release (or main) firmware for this, as it depends on PX4 modules crsf_rc. To add RC_CRSF_PRT_CFG to parameter list you need to create your own PX4 build
- Get PX4 repo and needed items for build (Follow this guide - Building PX4 Software | PX4 User Guide), i recommend using ubuntu or WSL ubuntu
- Build firmware for pixhawk 2.4.8, to do it run “make px4_fmu-v3_default”
- Change config by command “make px4_fmu-v3_default boardconfig”.
a)In the PX4 board config tool, navigate to the drivers submenu, then scroll down to highlight rc_input.
b) Use the enter key to remove the * from rc_input checkbox.
c) Scroll to highlight the RC submenu, then press enter to open it.
d) Scroll to highlight crsf_rc and press enter to enable it.
e) Save and exit the PX4 board config tool.
- Run build again “make px4_fmu-v3_default”
- Get your build in “\build” folder and install it to your pixhawk
- Set RC_CRSF_PRT_CFG to serail that you are using, in my case Serial 4/5 port
PS: I have connected my receiver to the Serial 4/5 port.
Useful links: Reptile Dragon 2 (RD2) Build | PX4 User Guide
Hello there , I am having a bit of trouble understanding it , I am totally new to this ,
I have a Pixhawk 2.4.8 with me and Mission Planner 1.3.80 and firmware Copter V4.4.1 OFFICIAL. I am planning to buy TX12 Mark II Radio Controller (with ELRS, Mode 2 , FCC region), , I won’t be getting a receiver along with the transmitter . Please suggest me some receiver.
and secondly If I have receiver and transmitter is it enough for me to actually be able to control the quadcopter? or do I have to buy any more additional hardware to properly interface all of them together?.
(I am not sure if I was clear , for example earlier I had Fsi6 Flysky Fs-I6 2.4G 6Ch Afhds Rc Transmitter Controller with Receiver, all I had to do was bind RC and receiver , connect receiver to Pixhawk 2.4.8 calibrate RC and I was able to fly) Is it the same case with the TX12 Mark II Radio Controller (with ELRS, Mode 2 , FCC region) too once I buy the receiver ? or do I have to buy any other convertor/ similar hardware for it to work with Pixhawk 2.4.8 and mission planner.
apologies for this long post , English isn’t my strongest point.
I still very confuse with all the parameter, is there any easy way?
This is what i found using Copilot:
Certainly! You can indeed use an ELRS (ExpressLRS) receiver with a Pixhawk 2.4.8 flight controller. Here are some key points to consider:
- ELRS Protocol:
- ELRS is an open-source implementation of the closed-source CRSF protocol from TBS (Team BlackSheep).
- It refers to both the over-the-air protocol and the protocol used between the radio receiver (RX) and the flight controller.
- ELRS is compatible with Pixhawk controllers.
- Serial Ports on Pixhawk 2.4.8:
- The Pixhawk 2.4.8 has six serial ports (UARTs) available for connecting peripherals.
- These ports are numbered from 1 to 6.
- Any of these UARTs can be used for ELRS communication.
- UART Numbering:
- The UART number often doesn’t directly match the serial port number on these ports.
- The serial port is what you configure, and the UART number is sometimes used for labeling.
- For ELRS, you do not need flow control, so any UART can be used.
- Choosing a UART:
- Since ELRS doesn’t require flow control, you can use any UART.
- The Pixhawk 2.4.8 has three general-purpose serial ports (Telem1, Telem2, and Telem3).
- You can connect your Radiomaster RP1 ELRS receiver to either the Telem2 or Telem3 port.
- Both are suitable choices, and you can configure them as needed.
Remember that ELRS is a great choice for long-range communication, and with the Pixhawk 2.4.8, you have flexibility in selecting the UART for your ELRS receiver. Happy flying!
Hope someone can help me out here.
