Battery voltage indicator
Hi everyone,
I need a little help when it comes to battery indication in QGC with Pixhawk 4 and Px4.
The problem is that I am using 14S battery at 58.8V and 60Ah. The voltage is too big for the Pixhawk 4 power management board so it is not routed through it. Instead ESC are connected directly to the batteries.
How can I provide battery voltage indication to QGC with such configuration?
Thank you a lot!
Mauch has great solutions which are working up to 14s battery. You might have a look !
Hi, thanks for the reply!
I think they offer only for Pixhawk 1 and 2.1
My hardware is Pixhawk 4.
Yes but you can request another cable
I’m using it with a Pixhawk 4 as well
Thanks a lot, your help is much appreciated.
