Hello, I’m running VTOL, but I’m inquiring about some problems.
It turns off with an airspeed sensor failure detected warning message immediately after Transition or when turning at a particular waypoint.
The important thing is that only the sensor is turned off, but when you check the log, the airspeed value is recorded as it is.
The sensor uses a 5525 sensor.
If you have experienced this or have a solution, please reply.
I have tried to change according to the various expectations below, but there are times when it works and times when it doesn’t.
- Steady state of the sensor module itself
- The difference between static and dynamic pressure according to the fixed state of the pitot tube and shaking
