Here is my test log. It flied ACRO mode around 35 secs.
Actually, I think it noisy some conditions. But I can not know about that.
Please help me.
How can I set the filter values?
My guess, IMU_GYRO_CUTOFF is around 90~100 and IMU_DGYRO_CUTOFF is around 90~100.
Am I right?
Which problem are you actually trying to solve? Is the tracking not good enough? Do you hear a vibration?
The flight looks quite clean; I’m not sure if you really need to change the filter settings but since the noise is at higher frequencies, you could try to increase the IMU_GYRO_CUTOFF (you could try 50, 60 and 70Hz) if you want to increase the rate loop gains.
I see. It could be caused by the derivative. You could try to reduce the IMU_DGYRO_CUTOFF to filter the derivative a bit more (or reduce the D gain if possible).
