Hi all, This is the setup I am using:
- X500v2 quadcopter
- Pixhawk 6X
- RP3 ELRS Receiver (Telem2)
- Sik 915 MHz Telemetry Radio (Telem1)
- M9N GPS (GPS1)
With everything connected, in QGC I will loose manual input just a few seconds after the connection is established even though the Tx and Rx module are still connected.
If I power everything off and remove the Sik radio, plug in the battery and plug directly into the pixhawk usb, manual control works until I increase throttle and after a few seconds or down throttle, the control is lost again.
I increased the COM_RC_LOSS_T parameter to 0.8sec from another post I saw, which didn’t seem to make any difference. Mav_0 is enabled on Telem1, Mav_1 is disabled and Mav_2 is set to Ethernet.
I am new to using Pixhawk/PX4 so sorry if I missed anything.
