Vehicle disarm in air
I had a weird situation where the vehicle disarmed mid air.
Looking at the log, there is a kill switch signal, but the pilot didn’t do it.
I’d be sure it was faulty signal from the receiver, but in input_rc.values.07, which is for the kill switch, I don’t see any signal change.
The difference on this flight was some different companion computer code, and I see larger CPU usage than usual, and more logging dropouts.
Maybe I’m missing something more obvious, I don’t know.
Log file:
https://logs.px4.io/plot_app?log=cafaf180-3d89-4583-9092-aefebd239ce4
Weird indeed. Maybe we got incredibly unlucky with the high sampling rate of input_rc (it only logs with an interval of 0.5s, compared to manual_control_setpoints with 0.025s).
Also other manual control inputs get crazy, .r and .aux1.
Actually, it is seen on px4io_status/raw_inputs.07.
That input should go to 2000us when a switch is flipped, but it only went to 1800us.
And from the start of flight, vehicle behaved kinda weird.
I tried changing the waypoint, and it took a few tries for it to accept my command from the QGC.
Since I don’t have the log from the transmitter, it’s kinda hard to tell where the fault was.
did you have any of the failsafes set to disarm? (Safety tab in QGC)
Nope. I don’t think it’s even possible to put it do disarm. Not something that should happen with failsafes.
Ok. Just FYI, all failsafes have a disarm/terminate option.
Yeah, you are right. Lockdown and kill are the same.
But anyway, i don’t have that enabled.
I have parachute in case of termination, but this unfortunately wasn’t that case, so it didn’t deploy.
