Using MAVROS to get/set parameter
Hi there,
https://pixhawk.org/firmware/parameters#parameter_reference gives a list of all the parameters.
I’m wondering how to use MAVROS to set the parameter.
I found this link mavros_msgs/ParamSet Documentation
But where can I find the param ID etc?
Many thanks!
If you want to modify manually fron console i recommend to use mavparam script.
Typical usage:
rosrun mavros mavparam dump -
If you want python - use helpers from mavros.param module.
Parameter ID == Name in that table.
