I wonder what is ROS equivalent of PARAM_SET message; I tried to use command DO_SET_PARAM but the parameter didn’t changed when it should…
Thanks in advance for helping
@Jaeyoung-Lim does parameter index in PX4 is enumerated at boot time? if yes, I think that will make use this command more difficult than I think…
guess I found the MAVROS solution (using param/set service)
