however in the log you sent they are applied to mav_0_* instead of mav_1_*
Yes, because it has been one of tries.
So these parameters look correct to me
No, because it doesn’t work at all. None of this parameters didn’t provide a communication.
Good to hear that it works now
I don’t think it should work this way. If you noticed, I’ve manually started mavlink instance in shell. On the next reboot it won’t work. To workaround, I can only write init-script, that will do the same things. But it sucks, actually.
Yes, you’re absolutely right.
The problem came from the file /fs/microsd/etc/extras.txt. I think it’s been one of our experiments with configuring mavlink stream rate. The content of this file was:
I’m really sorry for all this noise around the problem, shame on me.
But debugging this kind of bugs is really hard, because I didn’t find anything logged on alerted.
Thank you a lot @mrivi and @Jaeyoung-Lim
