Hi. I want to control fixed wing plane in unreal engine with px4 autopilot .I know there is a plugin for px4 with jsbsim, and jsbsim with unreal. so how can i use them together ?.Is there plugin? or is there another fixed wing flight dynamics model for unreal engine which i can use with px4?
I would point you to the following documentation:
PX4 is the Professional Autopilot. Developed by world-class developers from industry and academia, and supported by an active world wide community, it powers all kinds of vehicles from racing and cargo drones through to ground vehicles and...
Thanks for reply. I need fixed wing plane.as I know Airsim only have multirotor drone.
Seems like they have car & multirotor.
However there seems to have been some effort in implementing a plane model:
opened 02:39PM - 20 Aug 20 UTC
feature request
fastphysics
# Fixed Wing Vehicle Integration
I am working on adding a FixedWing aircraft … class into Airsim, so far I have been documenting my work under issue #2508 but as suggested by @rajat2004 it would be usefult to move this work to a new issue so as to improve visibility for others to work on.
### Work so far
Please see this [post](https://github.com/microsoft/AirSim/issues/2508#issuecomment-674392713) for a detailed breakdown of what has been added in my [forked Airsim repository under the fixedwing branch](https://github.com/AOS55/AirSim-1/tree/FixedWing). I will aim to keep updates on this issue of new files, classes, methods & functions with a view to write comprehensive documentation as the code begins to get to a state where it can be merged back into the master branch on the main repo.
Since the [last update post](https://github.com/microsoft/AirSim/issues/2508#issuecomment-674392713) on #2508 I have been updating the FixedWingLibClient files to enable communication with Ardupilot. A linked issue has been opened within the [ArduPilot Repo](https://github.com/ArduPilot/ardupilot/issues/15095).
### FixedWing Branch State
- Compilable from Visual Studio: 🟢
- Runs alone in UE4: 🟢
- Runs with ArduPilot and Mavlink in UE4 over network: 🔴
- Model validated with real comparison: 🔴
### Known issues
- I can't compile the code from source in Visual Studio please see the [chain](https://github.com/microsoft/AirSim/issues/2508#issuecomment-675355753) back in #2508 for what we have tried so far. I think it is most likely a mistake I have made in the source code. <-- This is currently the most pressing issue.
- I naievly initially implemented the control surfaces at seperate functions `getElevatorSignal()` etc. I am beginning to realise as I work through the control implementation this was not a good way to go about this and the program is already well setup to accept a more conventional control vector, i.e. the **u** vector in state-space form. I am planning to go back and correct this to a 4 row **u** vector.
- The Core APIs I effectively copied over when setting up the controller files include several aspects that I don't think make sense for a Fixed Wing aircraft, for example [commandVelocityHold](https://github.com/AOS55/AirSim-1/blob/FixedWing/AirLib/include/vehicles/fixedwing/firmwares/mavlink/MavLinkFixedWingApi.hpp#L551) uses the function `moveByLocalVelocity` that takes a boolean `yaw mode` switch and `rate` as a command these are set as `false` and `0` in the current implementation. But, `moveByLocalVelocity` may be better of if rewritten for fixedwing.
### Planned Future Work
Initially I am aiming to work to resolve all the known issues and turn all the 🔴 in the state to 🟢. Following from this I will aim to add the following functionality:
[ ] Construct a similar Python API as in multirotor <-- hopefully a short term objective
[ ] Implement Undercarriage for fixedWingLandings
[ ] Deep Reinforcement Learning (DRL) based FW landings <-- main PhD objective, expect to write & publish a paper based on this
[ ] Validate model and control on real UAV and FW aircraft, ties in with above.
### Motivation
Principally this is for my PhD at the [University of Bristol](https://www.bristol.ac.uk/) where I am aiming to use a combination of computer vision and Deep Reinforcement Learning to train an autonomous fixedwing agent/aircraft to navigate to and safely land in an unknown location. This is both with and without power and on a range of fixedwing aircraft including fixedWing UAVs, gliders & multiengine light piston aircraft (<5700Kg). Not only this but when discussing AirSim with my colleagues we believe that having a fixedWing simulator capable of highfidelity graphics and SITL that is efficient will be of great benefit.
### Ongoing Development
Several users have already been realy helpful (@rajat2004 😀), if anyone has any ideas about how to solve some of the issues I have described above all help is greatly appreciated. In particular if anyone is able to have any success compiling the [fixedwing source](https://github.com/AOS55/AirSim-1/tree/FixedWing) please let me know as I'm a little stumped 😕 as to why it won't compile.
