May 13, 2020
Agenda
- Status update by component/project
- Roadmap, and Release discussion
- Community Q&A
- In-Depth discussions
Join Meeting
Meeting ID: 946 175 205
Call in using your phone, find your local number: https://zoom.us/u/aetSYKbiMF
PX4 Virtual Developer Summit July 6 & 7
New website live: https://px4.io/virtual-2020/
Everyone in the community has the opportunity to have a 30 minutes slot for a talk or video. Get in touch and we might even adjust the schedule if it doesn’t fit your content.
Sales pitches for your product are not welcome. We are looking for technical content to help the community cooperate on the open-source projects.
Presentations can be in your native language and there will be regional content e.g. in China.
Ideas for content:
- Community tour: All the platforms, tools, places to find information and work together. Easy entry.
- How to set up: Software and Hardware how to get started.
- Hands-on tuning guide.
- Presentation of specific components.
There will be a real developer summit planned again when the global health situation is over.
Component update
Flight Testing
Still no official test team. We are trying to get a replacement soon.
System Architecture
All messages that are sent to the ground
OS / NuttX
@david_s5 NuttX made a new release 9.0.0, we didn’t test it yet.
Driver
Bosch sensors BMI55/88 tweaks to only publish valid data and have gyro and accel data synchronized.
There was a bug of the estimated gyro bias getting subtracted twice from the measurement.
Commander
No updates
Estimation
From @kamilritz: Enables usage of body position reference frame for VIO usage.
Our release blocking issue seems to be solved on master. We’re not exactly sure what made the difference.
MAVLink
This needs to be reverted. It’s deprecating frame types that we use and are replacing already deprecated other ones.
VTOL
Fixed Wing
Issue from release testing. Rudder wheel track
Multicopter
Workaround for acceleration feed-forward interfering with existing takeoff ramp logic.
Handle estimator attitude resets in between estimation change and new setpoint from position controller:
Optional setpoint filtering for Manual/Stabilized mode:
MAVSDK
C++ autogeneration is finished. @TSC21 contributed a feature for calibration.
Releases!
MAVSDK v0.26.0
MAVSDK v0.25.0
MAVSDK-Java v0.3.1
MAVSDK-Python coming tomorrow
Make sure to check out the release notes which will greatly simplify adaption work to new versions!
MAVROS / RTPS / ROS2
No updates
Avoidance
No updates
Simulation
MAVSDK CI test failure rate in CI is quite high.
@JulianOes was looking into it. There seem to be connection issues to simulation that he couldn’t reproduce locally. It could because by the dynamic multiple world spawning change.
@kamilritz Knows about the “ground truth” issue where the EKF sets local position true just at the beginning and if it takes off with the false flag
@Jaeyoung-Lim :
sitl_gazeboupdate results in a failure. It seems to be only offboard attitude control. Strange because the changes should not change the result. We need to check
UAVCAN
- @TSC21 The DS-015 UAVCAN Drone Standard RFC should be closed this week so the respective DSDL files can be written to mirror the messages on the spec.
- Progress by @dagar in the UAVCAN v1 integration in PX4 can be followed in:
e.g. bridging certain messages like battery status between UAVCAN v1 and uORB
There’s a drone specific UAVCAN weekly call. “UAVCAN Drone” on Tuesday in https://www.dronecode.org/calendar/. Any cooperation and help is appreciated. There’s a general (non donre specific) UAVCAN dev call on Wednesday. There’s a lot of progress at the moment.
PX4 v1.11.0-beta2 is out
Post your test flight logs on: PX4 1.11 Beta is here! Community Testing Week Starts Today!
Please help us testing and make sure everything you care about works as expected in the release. If you don’t know what to test there are prepared test cards available here: https://dev.px4.io/master/en/test_and_ci/test_flights.html
Community Q&A
Noone raised a question.
Gliding / Airspeed prioritization for fixed wing flight
@Jaeyoung-Lim We want to have fixed wing gliding and soaring control be available from offboard. Instead of making a new setpoint type the idea is to have a special e.g. negative mission throttle interpreted as command to glide so TECS prioritizes airspeed over holding altitude. Is that viable? @dagar We only need to check if any existing functionality interferes.
@sfuhrer How about enabling the feature for RC controlled flight? It would be useful to have a mode where it’s impossible to stall the vehicle but have manual control over throttle. @dagar wanted to enable that a long time ago since some commercial planes offer that as the lowest level operator proof mode.
@Jaeyoung-Lim The airplane in SITL does not stall. Default simulation environment will need to change for fixed-wing. How about using JSBSim as the headless simulator and use FlightGear as the visualization. SITL gazebo for fixed wing requires a lot of manual improvements since the lift/drag model does not account for stalling, zero angle of attack results in zero drag… It will not easily have good dynamics.
Errata and Feedback
