Title: PX4 v1.14 on custom FMUv4-style STM32F427 board: USB works in bootloader, but no /dev/ttyACM0 and no USB MAVLink in app firmware
Hi everyone,
I am bringing up a custom STM32F427 board based on the PX4 FMUv4 architecture on PX4 v1.14.
I currently have a USB issue that I cannot fully isolate:
What works
  • The board boots and PX4 app firmware runs
  • I can connect through telemetry UART
  • mavlink status shows one active MAVLink instance on:
    • /dev/ttyS1 @ 57600
  • Bootloader flashing over USB works
What does not work
  • QGroundControl does not connect over USB
  • In NSH, ls /dev does not show /dev/ttyACM0
  • So it looks like USB CDC ACM is not being created in the app firmware
Current observations
From NSH:
param show MAV_0_CONFIG
# MAV_0_CONFIG = 101
param show MAV_1_CONFIG
# MAV_1_CONFIG = 0
param show MAV_2_CONFIG
# MAV_2_CONFIG = 0
mavlink status
# instance #0 on /dev/ttyS1 @57600
ls /dev shows only:
/dev:
 console
 led0
 mmcsd0
 null
 ttyS0
 ttyS1
 ttyS2
 ttyS3
 ttyS4
 ttyS5
 ttyS6
So there is no /dev/ttyACM0.
Important board detail
My custom board does not have USB VBUS detect connected to PA9 like the original FMUv4.
Because of that, I modified board_config.h to force USB as connected/valid:
#define BOARD_ADC_USB_CONNECTED      (1)
#define BOARD_ADC_USB_VALID          (1)
NuttX / defconfig side
My defconfig already has USB-related options enabled, including:
CONFIG_CDCACM=y
CONFIG_SYSTEM_CDCACM=y
CONFIG_STM32_OTGFS=y
CONFIG_STM32_OTGFSDEV=y
CONFIG_USBDEV=y
Board init side
In my custom board init.c, I call:
stm32_usbinitialize();
However, my board usb.c currently has a very minimal implementation:
__EXPORT void stm32_usbinitialize(void)
    /* The OTG FS has an internal soft pull-up */
    /* Configure the OTG FS VBUS sensing GPIO, Power On, and Overcurrent GPIOs */
So basically the function is empty.
My question
For PX4 v1.14 on a custom FMUv4-style board without PA9 VBUS detect:
  1. Is forcing
    the correct approach?
  2. Should stm32_usbinitialize() remain empty in this case, or does it still need some board-specific USB FS setup even without a VBUS detect pin?
  3. If bootloader USB works but app firmware never creates /dev/ttyACM0, what would be the next file/path to inspect in v1.14:
    • board usb.c
    • NuttX board USB init
    • startup scripts
    • something else?
Any guidance from someone who has ported PX4 v1.14 to a custom STM32F4/FMUV4-like board would be really appreciated.
Thanks.
