Hi, I am sorry for stupid question, but I am new in the field.
When I make the command make px4_sitl gazebo-classic_iris , most of the time the interface of gazebo like this, the models and lights on the left column have nothing and I can’t add box in this world. But the iris can takeoff and land when I make the commander in the terminal.
But in few times, the models and lights on the left column have the models and I can modify the world.
I don’t know why and how to solve it.
I use the gazebo 11 and the latest px4.
I see the same. It happens to me maybe 1 in 10 times, and I just have to try again. I suspect it’s a Gazebo bug, or caused by a bug in one of the Gazebo plugins.
Thanks for your reply. It happens to me maybe 9 in 10 times. I want to add a lidar and get the data to build map. But I do nothing until it is solved, it is so frustrating.
Does it go away when you stash your changes? If so, it might be something wrong with the added/enabled code.
Actually, I re-install the PX4 and run the iris and standard_vtol. It still exist. The below is the output code:
make px4_sitl_default gazebo-classic_iris
[0/4] Performing build step for 'sitl_gazebo-classic'
ninja: no work to do.
[3/4] cd /home/a/PX4/PX4-Autopilot/bui...4/PX4-Autopilot/build/px4_sitl_default
SITL ARGS
sitl_bin: /home/a/PX4/PX4-Autopilot/build/px4_sitl_default/bin/px4
debugger: none
model: iris
world: none
src_path: /home/a/PX4/PX4-Autopilot
build_path: /home/a/PX4/PX4-Autopilot/build/px4_sitl_default
GAZEBO_PLUGIN_PATH :/home/a/PX4/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic
GAZEBO_MODEL_PATH :/home/a/PX4/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models
LD_LIBRARY_PATH /usr/lib/x86_64-linux-gnu/gazebo-11/plugins:/opt/ros/foxy/opt/yaml_cpp_vendor/lib:/opt/ros/foxy/opt/rviz_ogre_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:/home/a/PX4/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic
empty world, setting empty.world as default
Using: /home/a/PX4/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models/iris/iris.sdf
Warning [parser.cc:833] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
SITL COMMAND: "/home/a/PX4/PX4-Autopilot/build/px4_sitl_default/bin/px4" "/home/a/PX4/PX4-Autopilot/build/px4_sitl_default"/etc
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [px4] startup script: /bin/sh etc/init.d-posix/rcS 0
INFO [init] found model autostart file as SYS_AUTOSTART=10015
INFO [param] selected parameter default file parameters.bson
INFO [param] importing from 'parameters.bson'
INFO [parameters] BSON document size 316 bytes, decoded 316 bytes (INT32:13, FLOAT:3)
INFO [param] selected parameter backup file parameters_backup.bson
INFO [dataman] data manager file './dataman' size is 7866640 bytes
etc/init.d-posix/rcS: 39: [: Illegal number:
INFO [init] PX4_SIM_HOSTNAME: localhost
INFO [simulator_mavlink] Waiting for simulator to accept connection on TCP port 4560
INFO [simulator_mavlink] Simulator connected on TCP port 4560.
INFO [lockstep_scheduler] setting initial absolute time to 3436000 us
INFO [commander] LED: open /dev/led0 failed (22)
WARN [health_and_arming_checks] Preflight Fail: ekf2 missing data
Gazebo multi-robot simulator, version 11.13.0
Copyright (C) 2012 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 10.25.5.178
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 18570 remote port 14550
INFO [mavlink] mode: Onboard, data rate: 4000 B/s on udp port 14280 remote port 14030
INFO [mavlink] mode: Gimbal, data rate: 400000 B/s on udp port 13030 remote port 13280
INFO [logger] [logger] ./log/2023-06-17/01_14_21.ulg
INFO [logger] Opened full log file: ./log/2023-06-17/01_14_21.ulg
INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
pxh> INFO [tone_alarm] home set
INFO [tone_alarm] notify negative
INFO [commander] Ready for takeoff!
Not sure if this is the problem?
This also doesn’t look right.
Oh, try setting export VERBOSE_SIM=1 and check if you get more output!
Thanks for you help. I have solved this question by changing a better computer.
Alright. I wonder what the issue was though.
Maybe the low-end computers cannot run the gazebo well.
