r1_rover is an existing model, and after I deleted the sdf.jinja file and the mesh file, I inserted my code and called it. It is created through a make command on Gazebo, but it does not work with QGC.
apollo@apollo:~/PX4-Autopilot$ make px4_sitl gazebo-classic_r1_rover
[0/4] Performing build step for âsitl_gazebo-classicâ
ninja: no work to do.
[3/4] cd /home/apollo/PX4-Autopilot/buâŚo/PX4-Autopilot/build/px4_sitl_default
SITL ARGS
sitl_bin: /home/apollo/PX4-Autopilot/build/px4_sitl_default/bin/px4
debugger: none
model: r1_rover
world: none
src_path: /home/apollo/PX4-Autopilot
build_path: /home/apollo/PX4-Autopilot/build/px4_sitl_default
GAZEBO_PLUGIN_PATH :/home/apollo/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic
GAZEBO_MODEL_PATH :/home/apollo/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models
LD_LIBRARY_PATH :/home/apollo/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic
empty world, setting empty.world as default
Using: /home/apollo/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models/r1_rover/r1_rover.sdf
SITL COMMAND: â/home/apollo/PX4-Autopilot/build/px4_sitl_default/bin/px4â â/home/apollo/PX4-Autopilot/build/px4_sitl_defaultâ/etc
| ___ \ \ \ / / / |
| |/ / \ V / / /| |
| __/ / \ / /| |
| | / /^\ \ ___ |
_| / / |_/
px4 starting.
INFO [px4] startup script: /bin/sh etc/init.d-posix/rcS 0
INFO [init] found model autostart file as SYS_AUTOSTART=1061
INFO [param] selected parameter default file parameters.bson
INFO [param] importing from âparameters.bsonâ
INFO [parameters] BSON document size 408 bytes, decoded 408 bytes (INT32:14, FLOAT:6)
INFO [param] selected parameter backup file parameters_backup.bson
SYS_AUTOCONFIG: curr: 0 â new: 1
- SYS_AUTOSTART: curr: 10017 â new: 1061
- SENS_BOARD_X_OFF: curr: 0.0000 â new: 0.0000
- SENS_DPRES_OFF: curr: 0.0000 â new: 0.0010
Gazebo multi-robot simulator, version 11.12.0
Copyright (C) 2012 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.0.68
INFO [dataman] data manager file â./datamanâ size is 7866640 bytes
etc/init.d-posix/rcS: 39: [: Illegal number:
INFO [init] PX4_SIM_HOSTNAME: localhost
INFO [simulator_mavlink] Waiting for simulator to accept connection on TCP port 4560
INFO [simulator_mavlink] Simulator connected on TCP port 4560.
