I have a workspace with “Firmware” & “PX4-SITL_gazebo-classic” packages. I have included another package to control the drone comes by launching roslaunch px4 mavros_posix_sitl.launch. So, I created a c++ node that publishes a new position to mavros/setpoin_position/local, and I use QGroundControl first to take off the drone. The drone does not response once I run the node; however, I find the message already published to the topic mavros/setpoint_position/local! Also, the echo of mavros/state topic shows the current mode is mode: "AUTO.LOITER.
Here is the code I am using:
int main(int argc, char** argv)
// Initialize the node
ros::init(argc, argv, "drone_forward");
ros::NodeHandle nh;
// Create the arming client
ros::ServiceClient arming_client = nh.serviceClient<mavros_msgs::CommandBool>("/mavros/cmd/arming");
// Create the mode client
ros::ServiceClient set_mode_client = nh.serviceClient<mavros_msgs::SetMode>("/mavros/set_mode");
// Create the setpoint position publisher
ros::Publisher setpoint_pub = nh.advertise<mavros_msgs::PositionTarget>("/mavros/setpoint_position/local", 10);
// Wait for the services to become available
arming_client.waitForExistence();
set_mode_client.waitForExistence();
// Arm the drone
mavros_msgs::CommandBool arm_cmd;
arm_cmd.request.value = true;
if (!arming_client.call(arm_cmd)) {
ROS_ERROR("Failed to arm the drone");
return 1;
// Switch to OFFBOARD mode
mavros_msgs::SetMode offboard_mode_cmd;
offboard_mode_cmd.request.custom_mode = "OFFBOARD";
if (!set_mode_client.call(offboard_mode_cmd)) {
ROS_ERROR("Failed to set the flight mode to OFFBOARD");
return 1;
// Move the drone to a position 5 meters forward from the current position
geometry_msgs::PoseStamped pose_cmd;
pose_cmd.header.stamp = ros::Time::now();
pose_cmd.header.frame_id = "map";
pose_cmd.pose.position.x = 5.0;
setpoint_pub.publish(pose_cmd);
return 0;
In the code, I tried first to not change the mode and only publish the message, but the drone didn’t response. Hence, I switch the mode but I get this message on the terminal: CMD: Unexpected command 176, result 1.
I am new to the package, so excuse me if my explanation isn’t clear.
