I am working on MAV control in GPS denied environment using px4flow and Lidar sensor.While in simulation and during experiments on real vehicle, MAV doesnt stay at its position and drifts in random direction. I am using /mavros/local_position/pose msg to provide setpoints to the MAV. Currently it just have to takeoff hover and land at the same position. What might be causing this?
!/usr/bin/env python
import rospy
from geometry_msgs.msg import Point, PoseStamped
from mavros_msgs.msg import * from mavros_msgs.srv import *
class fcuModes: def init(self): pass
def setTakeoff(self):
rospy.wait_for_service(‘mavros/cmd/takeoff’)
try:
takeoffService = rospy.ServiceProxy(‘mavros/cmd/takeoff’, mavros_msgs.srv.CommandTOL)
takeoffService(altitude = 3)
except rospy.ServiceException, e:
print “Service takeoff call failed: %s”%e
def setArm(self):
rospy.wait_for_service(‘mavros/cmd/arming’)
try:
armService = rospy.ServiceProxy(‘mavros/cmd/arming’, mavros_msgs.srv.CommandBool)
armService(True)
print “Service arming call failed: %s”%e
def setDisarm(self):
try:
armService(False)
print “Service disarming call failed: %s”%e
def setStabilizedMode(self):
rospy.wait_for_service(‘mavros/set_mode’)
try:
flightModeService = rospy.ServiceProxy(‘mavros/set_mode’, mavros_msgs.srv.SetMode)
flightModeService(custom_mode=‘STABILIZED’)
print “service set_mode call failed: %s. Stabilized Mode could not be set.”%e
def setOffboardMode(self):
try:
flightModeService(custom_mode=‘OFFBOARD’)
print “service set_mode call failed: %s. Offboard Mode could not be set.”%e
def setAltitudeMode(self):
try:
flightModeService(custom_mode=‘ALTCTL’)
print “service set_mode call failed: %s. Altitude Mode could not be set.”%e
def setPositionMode(self):
try:
flightModeService(custom_mode=‘POSCTL’)
print “service set_mode call failed: %s. Position Mode could not be set.”%e
def setAutoLandMode(self):
try:
flightModeService(custom_mode=‘AUTO.LAND’)
print “service set_mode call failed: %s. Autoland Mode could not be set.”%e
class Controller:
def init(self):
# Drone state
self.state = State()
# Instantiate a setpoints message
self.sp = PositionTarget()
# set the flag to use position setpoints and yaw angle
self.sp.type_mask = int(‘010111111000’, 2)
# LOCAL_NED
self.sp.coordinate_frame = 1
# We will fly at a fixed altitude for now
# Altitude setpoint, [meters]
self.ALT_SP = 1.5
# update the setpoint message with the required altitude
self.sp.position.z = self.ALT_SP
# Step size for position update
self.STEP_SIZE = 2.0
# Fence. We will assume a square fence for now
self.FENCE_LIMIT = 5.0
# A Message for the current local position of the drone
self.local_pos = Point(0.0, 0.0, 1.0)
# initial values for setpoints
self.sp.position.x = 0.0
self.sp.position.y = 0.0
# speed of the drone is set using MPC_XY_CRUISE parameter in MAVLink
# using QGroundControl. By default it is 5 m/s.
# Callbacks
## local position callback
def posCb(self, msg):
self.local_pos.x = msg.pose.position.x
self.local_pos.y = msg.pose.position.y
self.local_pos.z = msg.pose.position.z
## Drone State callback
def stateCb(self, msg):
self.state = msg
## Update setpoint message
def updateSp(self):
self.sp.position.x = self.local_pos.x
self.sp.position.y = self.local_pos.y
def x_dir(self):
self.sp.position.x = self.local_pos.x + 5
def neg_x_dir(self):
self.sp.position.x = self.local_pos.x - 5
def y_dir(self):
self.sp.position.y = self.local_pos.y + 5
def neg_y_dir(self):
self.sp.position.y = self.local_pos.y - 5
def main():
rospy.init_node(‘pos_ctrl’, anonymous=True)
# flight mode object
modes = fcuModes()
cnt = Controller()
rate = rospy.Rate(20.0)
rospy.Subscriber(‘mavros/state’, State, cnt.stateCb)
# Subscribe to drone's local position
rospy.Subscriber(‘mavros/local_position/pose’, PoseStamped, cnt.posCb)
# Setpoint publisher
sp_pub = rospy.Publisher(‘mavros/setpoint_raw/local’, PositionTarget, queue_size=1)
# Make sure the drone is armed
while not cnt.state.armed:
modes.setArm()
rate.sleep()
# We need to send few setpoint messages, then activate OFFBOARD mode, to take effect
k=0
while k<10:
sp_pub.publish(cnt.sp)
rate.sleep()
k = k + 1
# activate OFFBOARD mode
modes.setOffboardMode()
# ROS main loop
while not rospy.is_shutdown():
x=0
while x<500:
rate.sleep()
cnt.updateSp()
rate.sleep()
x= x + 1
modes.setAutoLandMode()
if name == ‘main’: try: main() except rospy.ROSInterruptException: pass`
