I am running the PX4 SITL with Gazebo and am trying to command the
attitude using the setpoint_* topics. I am able to successfully connect
over UDP with mavros however when I publish to the
/mavros/setpoint_raw/attitude topic, the quadcopter in the Gazebo
environment immediately falls to the ground after commanding to OFFBOARD
mode. The “make posix_sitl default gazebo” terminal output then prints
out the warning “uORB::DeviceNode::publish called with invalid handle”
and the terminal output from the mavros node prints out the warning
“CMD: Unexpected command 176, result 0”.
This happens when I publish to both the
/mavros/setpoint_attitude/attitude and /mavros/setpoint_raw/attitude
topics however I am able to command position using the
/mavros/setpoint_position/local topic.
Any help would be appreciated.
