Hello everyone,
I’m working with a Pixhawk 6X flight controller and a Mauch Sensor Hub X 2, which allows power redundancy via two batteries in parallel, with current and voltage monitoring.
Questions:
- Is the Mauch Sensor Hub X2 supported in PX4 natively?
- If it is supported, what functionality is available? For example:
- Can PX4 correctly read and scale the combined voltage/current?
- Can I monitor both batteries individually (e.g., two
battery_statusinstances)? - Are battery failsafes triggered correctly based on combined input?
- If not supported out-of-the-box:
- Is there any known workaround?
- Would extending
analog_battery.cppto support multiple channels be a viable approach?
I would appreciate any guidance or suggestions. Thanks in advance!
