Ok so my issue is that i want to make a simulation where, i give command to the drone using mavsdk, but it want it to be on a ip address (non localhost) so in order to do that i have gone through the documentation and find out that there are different ways to archive this, and one of the option was to specify in the various config file where mavlink start is called to add the -t parameter with the ip_of_the_host, but the issue is that it provide just one single file as an example (that i have modified without any luck), and do not tell which are the others; does any of you guys know how can i archive my goal or eventually what are the other config file that i have to modify?
Thanks
