In my v1.9 FMU-v5 build, the SERVO_OUTPUT_RAW.* signals are not listed in the Widgets > Analyze charts. How do I enable them?
I’m in the process of bringing up a new flight controller based on the FMU-v5 design and I need to check what that the fmu is attempting to send signals to the motor controllers.
I have same issue. You can see SERVO_OUTPUT_RAW if you change UAVCAN_ENABLE parameter(Disabled). But there is a problem. The PWM data is not change. I don’t know why and no more progress.
