SBUS Output
Has anyone successfully been able to use the SBUS output on the pixhawk4? I don’t seem to be getting an SBUS to PWM converter to work properly. I don’t know if the channels are passed through by default or whether there is some additional setup that needs to be done?
https://ibb.co/pQW9pT3
https://ibb.co/CzNwXLB
https://ibb.co/ccdrR7d
hi,
is your GCS thro’ QGC
Yes it is. QGC.
My reply is too short so I need to fill in this extra line.
only the I/O, Main PWM values can be seen in SBUS out. if you trying with AUX/FMU PWM, it will not work.
Awesome, I will test and let post the results.
Ok, so apparently this info is not available anywhere. I always assumed that the SBUS was point to point. Apparently you can put other devices on the same bus so that’s what I’ve done to drive the SBUS gimbal from the receiver and effectively bypassing the PX4 as I could never get the SBUS out from the PX4 to properly pass-through.
