Hi guys, I am doing calibration via the terminal, I was wondering whether it is possible to save the data gathered from calibration so I do not have to calibrate each time?
Calibration is saved as parameters and generally parameters are automatically saved, so it’s not clear to me why the calibration would be lost after a restart.
Hmm well after each restart of the device I cannot arm because the magnetometer is not calibrated and first have to calibrate this device again.
Can I manually save these parameters such that it loads them again?
What PX4 version are you using and what hardware?
I am using PX4 1.9.0 running on custom hardware (quadcore A53)
I solved it, I removed the param load by mistake and that caused the calibration data to not load of course.
