Running Gazebo and PX4 SITL in different machines
I would like to run Gazebo and PX4 SITL in different machines, as my laptop struggles running both and the IDE while debugging.
From what I understand the connection between PX4-SITL and Gazebo is done via mavlink UDP messages.
Can the IP the UPD messages are sent and received to/from be changed ? How?
Thanks
On the same subnet set the param MAV_BROADCAST to 1. As you start sitl you can do this on the command line with
param set MAV_BROADCAST 1
You could also try running gazebo headless. That’s the only way it’s usable on my laptop.
HEADLESS=1 make posix_sitl_default gazebo_standard_vtol
Thanks for the command to run gazebo headless, very useful, I had resorted to killing gzclient everytime!
I’m having no luck however with the broadcast.
PX4 blocks with this message:
INFO [simulator] Waiting for initial data on UDP port 14560. Please start the flight simulator to proceed..
Do I have to do something equivalent on the gazebo side?
Is gazebo broadcasting too by default? or sending to localhost?
Thanks
Actually my setup is a bit different. I often run PX4 + gazebo on one machine, and QGC on another. I haven’t tried PX4 on one and Gazebo on another, but I don’t see why it wouldn’t work if you find where the connection is configured.
Here’s where Gazebo opens the mavlink connection. https://github.com/PX4/sitl_gazebo/blob/2c64ddd7419a96df36809411959f87d7b88e6e06/src/gazebo_mavlink_interface.cpp#L430
