RTSP stream in QGC
Hello everyone,
I am building monoplotting in Custom QGC, but i am not able to fetch rtsp video stream from the drone.
Error:
Desktop_Qt_6_6_3_GCC_64bit-Debug/Custom-QGroundControl...
QML debugging is enabled. Only use this in a safe environment.
qgc.qgcapplication: Settings location "/home/eliteGamer/.config/QGroundControl.org/Custom-QGroundControl Daily.ini" Is writable?: true
Filter rules "Log.debug=false\nqgc..debug=false\nGStreamerAPILog.debug=true\nqt.qml.connections=false"
LocalizationLog: Error loading source localization for "en_IN"
LocalizationLog: Error loading json localization for "en_IN"
VideoReceiverLog: gst_element_factory_make('tee') failed
VideoReceiverLog: Failed
MAVLinkLogManagerLog: MAVLink logs directory: "/home/eliteGamer/Documents/Custom-QGroundControl Daily/Logs"
(Custom-QGroundControl:15885): GLib-GObject-CRITICAL : 19:38:34.247: g_object_set: assertion 'G_IS_OBJECT (object)' failed
I’m having the same error with my self-compiled QGC
‘VideoReceiverLog: gst_element_factory_make(‘tee’) failed’
windows 11
QT 6.6.3
VS 2022
Gstreamer 1.24.9
