Hi, everyone.
I try to compile rtps for my FC with my macOS. However, it fails since the lackness of some files which should come with the standard installation of PX4 for Mac.
And here is the full output of the command: %make px4_fmu-v5_rtps
Last login: Tue Nov 16 12:00:42 on console
/Users/kevin/.zshrc:3: no such file or directory: export PATH=“/usr/local/sbin:$PATH”
kevin@chenqirongdeMacBook-Pro ~ % cd PX4-Autopilot
kevin@chenqirongdeMacBook-Pro PX4-Autopilot % make px4_fmu-v5_rtps
[0/1452] git submodule platforms/nuttx/NuttX/nuttx
[14/1452] Generating RTPS topic bridge
File “/Users/kevin/PX4-Autopilot/msg/tools/generate_microRTPS_bridge.py”, line 206, in
fastrtps_version = subprocess.check_output(
File “/usr/local/Cellar/python@3.9/3.9.7_1/Frameworks/Python.framework/Versions/3.9/lib/python3.9/subprocess.py”, line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “/usr/local/Cellar/python@3.9/3.9.7_1/Frameworks/Python.framework/Versions/3.9/lib/python3.9/subprocess.py”, line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘ldconfig -v 2>/dev/null | grep libfastrtps’ returned non-zero exit status 1.
[15/1452] git submodule platforms/nuttx/NuttX/apps
[16/1452] git submodule src/drivers/gps/devices
[20/1452] git submodule src/drivers/uavcan/libuavcan
[22/1452] git submodule src/modules/mavlink/mavlink
[24/1452] git submodule src/modules/micrortps_bridge/micro-CDR
[25/1452] Generating Mavlink developme…ssage_definitions/v1.0/development.xml
Validating /Users/kevin/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/development.xml
Parsing /Users/kevin/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/development.xml
Validating /Users/kevin/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/standard.xml
Parsing /Users/kevin/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/standard.xml
Validating /Users/kevin/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/common.xml
Parsing /Users/kevin/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/common.xml
Validating /Users/kevin/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/minimal.xml
Parsing /Users/kevin/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/minimal.xml
Merged enum MAV_CMD
Merged enum MAV_CMD
Found 222 MAVLink message types in 4 XML files
Generating C implementation in directory /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/mavlink/development
Generating C implementation in directory /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/mavlink/standard
Generating C implementation in directory /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/mavlink/common
Generating C implementation in directory /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/mavlink/minimal
Copying fixed headers for protocol 2.0 to /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/mavlink
[30/1452] Copying NuttX/nuttx to build/px4_fmu-v5_rtps/NuttX
skipping non-regular file “nuttx/boards/arm/stm32/emw3162/src/stm32_wlan_firmware.c”
[33/1452] Performing configure step for ‘px4io_firmware’
– PX4 version: v1.13.0-alpha1-3016-g6a60fba96d
– PX4 config file: /Users/kevin/PX4-Autopilot/boards/px4/io-v2/default.px4board
– PLATFORM nuttx
– TOOLCHAIN arm-none-eabi
– ARCHITECTURE cortex-m3
– CONSTRAINED_FLASH y
– PX4 config: px4_io-v2_default
– PX4 platform: nuttx
– cmake build type: MinSizeRel
– ccache enabled (export CCACHE_DISABLE=1 to disable)
– Configuring done
– Generating done
– Build files have been written to: /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/external/Build/px4io_firmware
[33/1452] Performing build step for ‘px4io_firmware’
[3/5] Linking CXX executable px4_io-v2_default.elf
Memory region Used Size Region Size %age Used
flash: 39388 B 60 KB 64.11%
sram: 2952 B 8 KB 36.04%
[5/5] Creating /Users/kevin/PX4-Autopi…d/px4io_firmware/px4_io-v2_default.px4
[1408/1452] Building CXX object src/mo…client.dir/microRTPS_transport.cpp.obj
FAILED: src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_transport.cpp.obj
/usr/local/bin/ccache /usr/local/bin/arm-none-eabi-g++ -DBOARD_WITH_IO -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DMODULE_NAME="micrortps_client" -DPX4_MAIN=micrortps_client_app_main -D_SYS_CDEFS_H_ -D_SYS_REENT_H_ -D__CUSTOM_FILE_IO__ -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -I/Users/kevin/PX4-Autopilot/boards/px4/fmu-v5/src -I/Users/kevin/PX4-Autopilot/platforms/nuttx/src/px4/common/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/lib -I/Users/kevin/PX4-Autopilot/platforms/nuttx/src/px4/stm/stm32f7/include -I/Users/kevin/PX4-Autopilot/platforms/common -I/Users/kevin/PX4-Autopilot/platforms/common/include -I/Users/kevin/PX4-Autopilot/src -I/Users/kevin/PX4-Autopilot/src/include -I/Users/kevin/PX4-Autopilot/src/lib -I/Users/kevin/PX4-Autopilot/src/lib/matrix -I/Users/kevin/PX4-Autopilot/src/modules -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/armv7-m -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/chip -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/common -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/apps/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/external/Install/include -I/Users/kevin/PX4-Autopilot/src/modules/micrortps_bridge/micrortps_client -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micrortps_client -I/Users/kevin/PX4-Autopilot/src/modules/micrortps_bridge/micro-CDR/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micro-CDR/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micro-CDR/include/microcdr -isystem /Users/kevin/PX4-Autopilot/platforms/nuttx/NuttX/include/cxx -isystem /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/include/cxx -isystem /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -Wno-stringop-truncation -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -nostdinc++ -fno-sized-deallocation -Wframe-larger-than=4096 -std=gnu++14 -MD -MT src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_transport.cpp.obj -MF src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_transport.cpp.obj.d -o src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_transport.cpp.obj -c /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micrortps_client/microRTPS_transport.cpp
arm-none-eabi-g++: error: /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micrortps_client/microRTPS_transport.cpp: No such file or directory
arm-none-eabi-g++: fatal error: no input files
compilation terminated.
[1409/1452] Building CXX object src/mo…ps_client.dir/microRTPS_client.cpp.obj
FAILED: src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_client.cpp.obj
/usr/local/bin/ccache /usr/local/bin/arm-none-eabi-g++ -DBOARD_WITH_IO -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DMODULE_NAME="micrortps_client" -DPX4_MAIN=micrortps_client_app_main -D_SYS_CDEFS_H_ -D_SYS_REENT_H_ -D__CUSTOM_FILE_IO__ -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -I/Users/kevin/PX4-Autopilot/boards/px4/fmu-v5/src -I/Users/kevin/PX4-Autopilot/platforms/nuttx/src/px4/common/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/lib -I/Users/kevin/PX4-Autopilot/platforms/nuttx/src/px4/stm/stm32f7/include -I/Users/kevin/PX4-Autopilot/platforms/common -I/Users/kevin/PX4-Autopilot/platforms/common/include -I/Users/kevin/PX4-Autopilot/src -I/Users/kevin/PX4-Autopilot/src/include -I/Users/kevin/PX4-Autopilot/src/lib -I/Users/kevin/PX4-Autopilot/src/lib/matrix -I/Users/kevin/PX4-Autopilot/src/modules -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/armv7-m -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/chip -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/common -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/apps/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/external/Install/include -I/Users/kevin/PX4-Autopilot/src/modules/micrortps_bridge/micrortps_client -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micrortps_client -I/Users/kevin/PX4-Autopilot/src/modules/micrortps_bridge/micro-CDR/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micro-CDR/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micro-CDR/include/microcdr -isystem /Users/kevin/PX4-Autopilot/platforms/nuttx/NuttX/include/cxx -isystem /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/include/cxx -isystem /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -Wno-stringop-truncation -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -nostdinc++ -fno-sized-deallocation -Wframe-larger-than=4096 -std=gnu++14 -MD -MT src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_client.cpp.obj -MF src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_client.cpp.obj.d -o src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_client.cpp.obj -c /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micrortps_client/microRTPS_client.cpp
arm-none-eabi-g++: error: /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micrortps_client/microRTPS_client.cpp: No such file or directory
[1410/1452] Building CXX object src/mo…ient.dir/microRTPS_client_main.cpp.obj
FAILED: src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_client_main.cpp.obj
/usr/local/bin/ccache /usr/local/bin/arm-none-eabi-g++ -DBOARD_WITH_IO -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DMODULE_NAME="micrortps_client" -DPX4_MAIN=micrortps_client_app_main -D_SYS_CDEFS_H_ -D_SYS_REENT_H_ -D__CUSTOM_FILE_IO__ -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -I/Users/kevin/PX4-Autopilot/boards/px4/fmu-v5/src -I/Users/kevin/PX4-Autopilot/platforms/nuttx/src/px4/common/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/lib -I/Users/kevin/PX4-Autopilot/platforms/nuttx/src/px4/stm/stm32f7/include -I/Users/kevin/PX4-Autopilot/platforms/common -I/Users/kevin/PX4-Autopilot/platforms/common/include -I/Users/kevin/PX4-Autopilot/src -I/Users/kevin/PX4-Autopilot/src/include -I/Users/kevin/PX4-Autopilot/src/lib -I/Users/kevin/PX4-Autopilot/src/lib/matrix -I/Users/kevin/PX4-Autopilot/src/modules -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/armv7-m -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/chip -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/arch/arm/src/common -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/apps/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/external/Install/include -I/Users/kevin/PX4-Autopilot/src/modules/micrortps_bridge/micrortps_client -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micrortps_client -I/Users/kevin/PX4-Autopilot/src/modules/micrortps_bridge/micro-CDR/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micro-CDR/include -I/Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/src/modules/micrortps_bridge/micro-CDR/include/microcdr -isystem /Users/kevin/PX4-Autopilot/platforms/nuttx/NuttX/include/cxx -isystem /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/include/cxx -isystem /Users/kevin/PX4-Autopilot/build/px4_fmu-v5_rtps/NuttX/nuttx/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -Wno-stringop-truncation -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -nostdinc++ -fno-sized-deallocation -Wframe-larger-than=4096 -std=gnu++14 -MD -MT src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_client_main.cpp.obj -MF src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_client_main.cpp.obj.d -o src/modules/micrortps_bridge/micrortps_client/CMakeFiles/modules__micrortps_bridge__micrortps_client.dir/microRTPS_client_main.cpp.obj -c /Users/kevin/PX4-Autopilot/src/modules/micrortps_bridge/micrortps_client/microRTPS_client_main.cpp
/Users/kevin/PX4-Autopilot/src/modules/micrortps_bridge/micrortps_client/microRTPS_client_main.cpp:34:10: fatal error: microRTPS_transport.h: No such file or directory
34 | #include <microRTPS_transport.h>
[1412/1452] Generating px4 event json file from source
make: *** [px4_fmu-v5_rtps] Error 1
