First time Build failure
Hi team, I tried to build using following command, but got following errors.
Need help.
make px4_fmu-v5_default
– PX4 version: v1.11.0-rc3-1543-g59b31e3c5b
– PX4 config file: /home/tushar/PX4-Autopilot/boards/px4/fmu-v5/default.cmake
– PX4 config: px4_fmu-v5_default
– PX4 platform: nuttx
– cmake build type: MinSizeRel
– The CXX compiler identification is GNU 6.3.1
– The C compiler identification is GNU 6.3.1
– Found assembler: /usr/bin/arm-none-eabi-gcc
– Check for working CXX compiler: /usr/bin/arm-none-eabi-g++
– Check for working CXX compiler: /usr/bin/arm-none-eabi-g++ – works
– Check for working C compiler: /usr/bin/arm-none-eabi-gcc
– Check for working C compiler: /usr/bin/arm-none-eabi-gcc – works
– Enabling double FP precision hardware instructions
– ccache enabled (export CCACHE_DISABLE=1 to disable)
– Found PythonInterp: /usr/bin/python3 (found suitable version “3.6.9”, minimum required is “3”)
– build type is MinSizeRel
– PX4 ECL: Very lightweight Estimation & Control Library v1.9.0-rc1-522-gffab483
– Building and including px4_io-v2_default
– Found PythonInterp: /usr/bin/python3 (found version “3.6.9”)
– Using C++11
– Release build type: MinSizeRel
– ROMFS: px4fmu_common
– ROMFS: Adding rc.board_defaults
– ROMFS: Adding rc.board_sensors
– ROMFS: Adding rc.board_mavlink
– Configuring done
– Generating done
– Build files have been written to: /home/tushar/PX4-Autopilot/build/px4_fmu-v5_default
[0/1471] git submodule platforms/nuttx/NuttX/nuttx
[2/1471] git submodule platforms/nuttx/NuttX/apps
[4/1471] git submodule src/lib/ecl
[12/1471] git submodule src/drivers/gps/devices
[15/1471] git submodule src/drivers/uavcan/libuavcan
[18/1471] git submodule mavlink/include/mavlink/v2.0
[21/1471] git submodule src/examples/gyro_fft/CMSIS_5
[812/1471] Building CXX object src/dri…h__bmi055.dir/BMI055_Gyroscope.cpp.obj
FAILED: src/drivers/imu/bosch/bmi055/CMakeFiles/drivers__imu__bosch__bmi055.dir/BMI055_Gyroscope.cpp.obj
/usr/bin/ccache /usr/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DMODULE_NAME=“bmi055” -DPX4_MAIN=bmi055_app_main -D_SYS_CDEFS_H_ -D_SYS_REENT_H_ -D__CUSTOM_FILE_IO__ -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -I…/…/boards/px4/fmu-v5/src -I…/…/platforms/nuttx/src/px4/common/include -I. -Isrc/lib -I…/…/platforms/nuttx/src/px4/stm/stm32f7/include -I…/…/platforms/common/include -I…/…/src -I…/…/src/include -I…/…/src/lib -I…/…/src/lib/matrix -I…/…/src/modules -INuttX/nuttx/arch/arm/src/armv7-m -INuttX/nuttx/arch/arm/src/chip -INuttX/nuttx/arch/arm/src/common -INuttX/apps/include -Iexternal/Install/include -isystem …/…/platforms/nuttx/NuttX/include/cxx -isystem NuttX/nuttx/include/cxx -isystem NuttX/nuttx/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=auto -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -nostdinc++ -fno-sized-deallocation -Wframe-larger-than=2048 -std=gnu++14 -MD -MT src/drivers/imu/bosch/bmi055/CMakeFiles/drivers__imu__bosch__bmi055.dir/BMI055_Gyroscope.cpp.obj -MF src/drivers/imu/bosch/bmi055/CMakeFiles/drivers__imu__bosch__bmi055.dir/BMI055_Gyroscope.cpp.obj.d -o src/drivers/imu/bosch/bmi055/CMakeFiles/drivers__imu__bosch__bmi055.dir/BMI055_Gyroscope.cpp.obj -c …/…/src/drivers/imu/bosch/bmi055/BMI055_Gyroscope.cpp
In file included from …/…/platforms/common/include/px4_platform_common/i2c_spi_buses.h:43:0,
from …/…/src/drivers/imu/bosch/bmi055/BMI055.hpp:39,
from …/…/src/drivers/imu/bosch/bmi055/BMI055_Gyroscope.hpp:36,
from …/…/src/drivers/imu/bosch/bmi055/BMI055_Gyroscope.cpp:34:
…/…/platforms/common/include/px4_platform_common/atomic.h: In instantiation of ‘bool px4::atomic::compare_exchange(T*, T) [with T = unsigned int]’:
…/…/src/drivers/imu/bosch/bmi055/BMI055_Gyroscope.cpp:326:71: required from here
…/…/platforms/common/include/px4_platform_common/atomic.h:169:34: error: parameter ‘expected’ set but not used [-Werror=unused-but-set-parameter]
inline bool compare_exchange(T *expected, T desired)
compilation terminated due to -Wfatal-errors.
cc1plus: all warnings being treated as errors
[813/1471] Building CXX object src/dri…mi055.dir/BMI055_Accelerometer.cpp.obj
FAILED: src/drivers/imu/bosch/bmi055/CMakeFiles/drivers__imu__bosch__bmi055.dir/BMI055_Accelerometer.cpp.obj
/usr/bin/ccache /usr/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DMODULE_NAME=“bmi055” -DPX4_MAIN=bmi055_app_main -D_SYS_CDEFS_H_ -D_SYS_REENT_H_ -D__CUSTOM_FILE_IO__ -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -I…/…/boards/px4/fmu-v5/src -I…/…/platforms/nuttx/src/px4/common/include -I. -Isrc/lib -I…/…/platforms/nuttx/src/px4/stm/stm32f7/include -I…/…/platforms/common/include -I…/…/src -I…/…/src/include -I…/…/src/lib -I…/…/src/lib/matrix -I…/…/src/modules -INuttX/nuttx/arch/arm/src/armv7-m -INuttX/nuttx/arch/arm/src/chip -INuttX/nuttx/arch/arm/src/common -INuttX/apps/include -Iexternal/Install/include -isystem …/…/platforms/nuttx/NuttX/include/cxx -isystem NuttX/nuttx/include/cxx -isystem NuttX/nuttx/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=auto -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -nostdinc++ -fno-sized-deallocation -Wframe-larger-than=2048 -std=gnu++14 -MD -MT src/drivers/imu/bosch/bmi055/CMakeFiles/drivers__imu__bosch__bmi055.dir/BMI055_Accelerometer.cpp.obj -MF src/drivers/imu/bosch/bmi055/CMakeFiles/drivers__imu__bosch__bmi055.dir/BMI055_Accelerometer.cpp.obj.d -o src/drivers/imu/bosch/bmi055/CMakeFiles/drivers__imu__bosch__bmi055.dir/BMI055_Accelerometer.cpp.obj -c …/…/src/drivers/imu/bosch/bmi055/BMI055_Accelerometer.cpp
from …/…/src/drivers/imu/bosch/bmi055/BMI055_Accelerometer.hpp:36,
from …/…/src/drivers/imu/bosch/bmi055/BMI055_Accelerometer.cpp:34:
…/…/src/drivers/imu/bosch/bmi055/BMI055_Accelerometer.cpp:328:71: required from here
[814/1471] Building CXX object src/dri…ensense__icm20602.dir/ICM20602.cpp.obj
FAILED: src/drivers/imu/invensense/icm20602/CMakeFiles/drivers__imu__invensense__icm20602.dir/ICM20602.cpp.obj
/usr/bin/ccache /usr/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DMODULE_NAME=“icm20602” -DPX4_MAIN=icm20602_app_main -D_SYS_CDEFS_H_ -D_SYS_REENT_H_ -D__CUSTOM_FILE_IO__ -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -I…/…/boards/px4/fmu-v5/src -I…/…/platforms/nuttx/src/px4/common/include -I. -Isrc/lib -I…/…/platforms/nuttx/src/px4/stm/stm32f7/include -I…/…/platforms/common/include -I…/…/src -I…/…/src/include -I…/…/src/lib -I…/…/src/lib/matrix -I…/…/src/modules -INuttX/nuttx/arch/arm/src/armv7-m -INuttX/nuttx/arch/arm/src/chip -INuttX/nuttx/arch/arm/src/common -INuttX/apps/include -Iexternal/Install/include -isystem …/…/platforms/nuttx/NuttX/include/cxx -isystem NuttX/nuttx/include/cxx -isystem NuttX/nuttx/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=auto -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -nostdinc++ -fno-sized-deallocation -Wframe-larger-than=2048 -std=gnu++14 -MD -MT src/drivers/imu/invensense/icm20602/CMakeFiles/drivers__imu__invensense__icm20602.dir/ICM20602.cpp.obj -MF src/drivers/imu/invensense/icm20602/CMakeFiles/drivers__imu__invensense__icm20602.dir/ICM20602.cpp.obj.d -o src/drivers/imu/invensense/icm20602/CMakeFiles/drivers__imu__invensense__icm20602.dir/ICM20602.cpp.obj -c …/…/src/drivers/imu/invensense/icm20602/ICM20602.cpp
In file included from …/…/platforms/common/include/px4_platform_common/atomic_bitset.h:36:0,
from …/…/src/modules/uORB/uORBDeviceMaster.hpp:54,
from …/…/src/modules/uORB/uORBDeviceNode.hpp:37,
from …/…/src/modules/uORB/PublicationMulti.hpp:44,
from …/…/src/lib/drivers/accelerometer/PX4Accelerometer.hpp:39,
from …/…/src/drivers/imu/invensense/icm20602/ICM20602.hpp:46,
from …/…/src/drivers/imu/invensense/icm20602/ICM20602.cpp:34:
…/…/src/drivers/imu/invensense/icm20602/ICM20602.cpp:406:76: required from here
[815/1471] Building CXX object src/dri…ensense__icm20689.dir/ICM20689.cpp.obj
FAILED: src/drivers/imu/invensense/icm20689/CMakeFiles/drivers__imu__invensense__icm20689.dir/ICM20689.cpp.obj
/usr/bin/ccache /usr/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DMODULE_NAME=“icm20689” -DPX4_MAIN=icm20689_app_main -D_SYS_CDEFS_H_ -D_SYS_REENT_H_ -D__CUSTOM_FILE_IO__ -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -I…/…/boards/px4/fmu-v5/src -I…/…/platforms/nuttx/src/px4/common/include -I. -Isrc/lib -I…/…/platforms/nuttx/src/px4/stm/stm32f7/include -I…/…/platforms/common/include -I…/…/src -I…/…/src/include -I…/…/src/lib -I…/…/src/lib/matrix -I…/…/src/modules -INuttX/nuttx/arch/arm/src/armv7-m -INuttX/nuttx/arch/arm/src/chip -INuttX/nuttx/arch/arm/src/common -INuttX/apps/include -Iexternal/Install/include -isystem …/…/platforms/nuttx/NuttX/include/cxx -isystem NuttX/nuttx/include/cxx -isystem NuttX/nuttx/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=auto -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -nostdinc++ -fno-sized-deallocation -Wframe-larger-than=2048 -std=gnu++14 -MD -MT src/drivers/imu/invensense/icm20689/CMakeFiles/drivers__imu__invensense__icm20689.dir/ICM20689.cpp.obj -MF src/drivers/imu/invensense/icm20689/CMakeFiles/drivers__imu__invensense__icm20689.dir/ICM20689.cpp.obj.d -o src/drivers/imu/invensense/icm20689/CMakeFiles/drivers__imu__invensense__icm20689.dir/ICM20689.cpp.obj -c …/…/src/drivers/imu/invensense/icm20689/ICM20689.cpp
from …/…/src/drivers/imu/invensense/icm20689/ICM20689.hpp:46,
from …/…/src/drivers/imu/invensense/icm20689/ICM20689.cpp:34:
…/…/src/drivers/imu/invensense/icm20689/ICM20689.cpp:382:79: required from here
[817/1471] Performing configure step for ‘px4io_firmware’
– PX4 config file: /home/tushar/PX4-Autopilot/boards/px4/io-v2/default.cmake
– PX4 config: px4_io-v2_default
– Configuring done
– Generating done
– Build files have been written to: /home/tushar/PX4-Autopilot/build/px4_fmu-v5_default/external/Build/px4io_firmware
Hi @shawngrimm,
Which OS are you using? Have you followed this: https://docs.px4.io/master/en/dev_setup/dev_env.html#development-environment ?
Hi @bresch
Yes I followed that.
I am using Linux 18.04
Hi @bresch @shawngrimm
I am seeing an error that seems similar to me - when building “make px4_fmu-v5_default”
Working on Ubuntu 18.04.6 LTS
performing “make distclean” before build did not help.
Could it be related to submodules? or something in the environment?
Would appreciate your help to resolve.
log snippet:
[26/1145] Building CXX object src/drivers/uavcan/libuavcan/libuavcan/CMakeFiles/uavcan.dir/src/marshal/uc_bit_array_copy.cpp.obj
FAILED: src/drivers/uavcan/libuavcan/libuavcan/CMakeFiles/uavcan.dir/src/marshal/uc_bit_array_copy.cpp.obj
/usr/bin/ccache /opt/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DUAVCAN_CPP_VERSION=UAVCAN_CPP03 -DUAVCAN_DRIVER=uavcan_stm32 -DUAVCAN_IMPLEMENT_PLACEMENT_NEW=1 -DUAVCAN_MEM_POOL_BLOCK_SIZE=48 -DUAVCAN_NO_ASSERTIONS -DUAVCAN_PLATFORM=generic -DUAVCAN_STM32_NUM_IFACES=2 -DUAVCAN_STM32_NUTTX=1 -DUAVCAN_STM32_TIMER_NUMBER=6 -D_SYS_CDEFS_H_ -D_SYS_REENT_H_ -D__CUSTOM_FILE_IO__ -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/boards/px4/fmu-v5/src -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/src/px4/common/include -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/build/px4_fmu-v5_default -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/build/px4_fmu-v5_default/src/lib -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/src/px4/stm/stm32f7/include -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/common -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/common/include -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/include -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/lib -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/lib/matrix -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/modules -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/nuttx/arch/arm/src/armv7-m -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/nuttx/arch/arm/src/chip -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/nuttx/arch/arm/src/common -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/apps/include -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/build/px4_fmu-v5_default/external/Install/include -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/drivers/uavcan/libuavcan/./libuavcan/include -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/drivers/uavcan/libuavcan/./libuavcan/include/dsdlc_generated -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/drivers/uavcan/libuavcan/libuavcan/include/dsdlc_generated -I/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/drivers/uavcan/libuavcan/libuavcan/include -isystem /home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/include/cxx -isystem /home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/nuttx/include/cxx -isystem /home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/nuttx/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Wall -Wextra -Wundef -std=c++11 -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -fno-rtti -nostdinc++ -fno-sized-deallocation -Wno-cast-align -Wno-deprecated-copy -Wno-address-of-packed-member -std=gnu++14 -MD -MT src/drivers/uavcan/libuavcan/libuavcan/CMakeFiles/uavcan.dir/src/marshal/uc_bit_array_copy.cpp.obj -MF src/drivers/uavcan/libuavcan/libuavcan/CMakeFiles/uavcan.dir/src/marshal/uc_bit_array_copy.cpp.obj.d -o src/drivers/uavcan/libuavcan/libuavcan/CMakeFiles/uavcan.dir/src/marshal/uc_bit_array_copy.cpp.obj -c /home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/drivers/uavcan/libuavcan/libuavcan/src/marshal/uc_bit_array_copy.cpp
In file included from /home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/drivers/uavcan/libuavcan/./libuavcan/include/uavcan/util/templates.hpp:10:0,
                 from /home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/drivers/uavcan/libuavcan/./libuavcan/include/uavcan/marshal/bit_stream.hpp:10,
                 from /home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/src/drivers/uavcan/libuavcan/libuavcan/src/marshal/uc_bit_array_copy.cpp:5:
/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/include/cxx/cmath: In function 'bool std::isfinite(double)':
/home/ANT.AMAZON.COM/rlamachi/workspace/PX4-Autopilot/platforms/nuttx/NuttX/include/cxx/cmath:60:13: error: conflicting declaration of C function 'bool std::isfinite(double)'
 inline bool isfinite(double value) { return __builtin_isfinite(value); }
@Ronen_Lam did you try to update the submodules?
git submodule sync --recursive && git submodule update --init --recursive
This while a back, but If I recall correctly I did resolve it with updating all the submoudles
