Hi.
I am aware that px4 has started to support Bebop 2. I was wondering if it is possible to install ROS, and then MAVROS, on the Bebop 2?
Thanks.
Hi.
Thanks.
you dont install ros or mavros on a FCU. you need a linux powered embedded system which is flying with your copter. and you need a USB or UART Connection to your FCU. I dont know if bebop supports it.
so you need a odroid for example and you need to power it from your battery.
you should start here: http://dev.px4.io/
Well, I thought that Bebop has Cortex A9 quad core processor, which can act as a companion computer. I have been using odroid with a pixhawk a lot!
But it would be more compact if it can be done on Bebop 2, 2 in 1 (companion computer and flight control code at the same time.
