Remote ID for Pixhawk/QGroundControl
Greetings. I have six custom drones running PX4 1.13.3, using QGC as ground control. They are all registered as Part 107 drones. I will shortly have to equip all of them with a remote ID module to meet the FAA’s Sept 16, 2023 deadline.
There are currently four products approved by FAA, and are available for sale. They all seem to operate completely independent of the drone control system and ground control station. However, there has to be some way to monitor the outgoing signals. Any thoughts about this? Will QGC be adding some functionality for this? I could use some direction from the developers and/or Auterion.
Thanks,
Joe
QGC supports Open Drone ID as defined by the MAVLink group here Open Drone ID Protocol · MAVLink Developer Guide
For more info on support at the QGC level you can start here https://github.com/mavlink/qgroundcontrol/pull/10600
Good luck.
I’ve obtained my operator id from french platform alphatango
and i have a problem with qground control, the error is "Operator ID invalid’. how can i solve this error?
I suggest you watch this issue, I have raised this to devs in the discord channel Operator id invalid: FRA-RP-XXXXXXXXXXXX · Issue #11750 · mavlink/qgroundcontrol · GitHub
Hey,
Im the original author on the github issue.
Holybro said to me (by email) that their openid module wasn’t appropriate for DIY usage.
I’ve gave up on this
but if you have news I’d like to hear about it
I dont want this for DIY usage.
What is the solution I didn’t any answer to that topic.
Thanks again.
But i think it is not related to holybro module this is related to qground control
Hey,
I guess mine was also saying something like this. But still you broadcast this and fly. Should not be an issue.
I need to check on that with the latest main or stable though. The last time I checked was with 1.14.
In Europe regulations, you should set operator ID and broadcast it, it isn’t brodcasted if it isn’t validate.
