I am facing weird issues. I am trying out different scenarios to get this to work but so far my results are far from safe, which is frustrating. Here are some of my experimental observations:
Channel 1 =Motor
Channel 2 =Elevator (PWM Reverse)
Channel 3 =Aileron
Channel 4=Pitch (PWM Reverse)
Channel 5=Rudder
Observation: Opposite Pitch Stabilization. Pitch RC Control OK. Roll Control opposed. Roll Stabilization OK.
Channel 1 =Motor
Channel 2 =Elevator
Channel 3 =Aileron (PWM Reverse)
Channel 4=Pitch
Channel 5=Rudder
Observation: Directions confirmed. Roll stabilization reversed…
Channel 1 =Motor
Channel 2 =Elevator (RC Reverse)
Channel 3 =Aileron
Channel 5=Rudder
Observation: Roll, Pitch & Yaw Stabilization confirmed. Elevator and roll control Reversed.
I can not seem to find a balance where my helicopter will stabilize and have correct actuation by RC. I have a feeling it might be because I am using Blade 130x Airframe setup on a T-REX250. The differences are that the elevator servo is at the back instead of the front. Maybe an issue with the mixer? Do you have any suggestions?
Regards, Junaid.
