I’ve posted this to the gazebo forums here
I am working on a quadcopter model. Initially I modified the 3DR Solo model to just change the mesh, inertia, and rotor joints to match my geometry. The aircraft flies fine (other than poorly tuned controller gains).
I wanted the motors modelled, since they currently aren’t in my mesh so I added in 4 cylinders attached to the base with fixed joints. When I do this I get a bunch of IMU problems and the accelerometers reading incorrect values.
> pxh> INFO [mavlink] partner IP: 127.0.0.1
INFO [ecl/EKF] EKF aligned, (pressure height, IMU buf: 22, OBS buf: 14)
[Wrn] [GuiIface.cc:120] Failed to get QCocoaScreen for NSObject(0x0)
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/quad_x_custom/motor_speed/3, deleting message. This warning is printed only once.
WARN [commander] Preflight Fail: Accel Range, hold still on arming
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/quad_x_custom/motor_speed/1, deleting message. This warning is printed only once.
INFO [ecl/EKF] EKF GPS checks passed (WGS-84 origin set)
INFO [ecl/EKF] EKF commencing GPS fusion
WARN [ecl/EKF] EKF baro hgt timeout - reset to baro
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/quad_x_custom/motors, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/quad_x_custom/motor_speed/2, deleting message. This warning is printed only once.
px4>sensors status
INFO [sensors] gyro status:
INFO [ecl/validation] validator: best: 0, prev best: 0, failsafe: NO (0 events)
INFO [ecl/validation] sensor #0, prio: 100, state: OK
INFO [ecl/validation] val: -0.0238, lp: -0.0377 mean dev: 0.0000 RMS: 0.0086 conf: 1.0000
INFO [ecl/validation] val: -0.0310, lp: -0.0137 mean dev: 0.0001 RMS: 0.0084 conf: 1.0000
INFO [ecl/validation] val: -0.0096, lp: -0.0122 mean dev: -0.0001 RMS: 0.0083 conf: 1.0000
INFO [sensors] accel status:
INFO [ecl/validation] val: -0.0478, lp: 0.0485 mean dev: 0.0037 RMS: 0.1045 conf: 1.0000
INFO [ecl/validation] val: -2.4719, lp: -2.5461 mean dev: 0.0070 RMS: 0.1087 conf: 1.0000
INFO [ecl/validation] val: -2.4057, lp: -2.4644 mean dev: 0.1297 RMS: 0.9791 conf: 1.0000
The model that works is almost an exact replica of solo.sdf
Here is the output of sensors status for the working version
pxh> sensors status
INFO [ecl/validation] val: -0.0258, lp: -0.0124 mean dev: -0.0005 RMS: 0.0095 conf: 1.0000
INFO [ecl/validation] val: -0.0043, lp: -0.0134 mean dev: 0.0002 RMS: 0.0082 conf: 1.0000
INFO [ecl/validation] val: -0.0141, lp: -0.0115 mean dev: -0.0001 RMS: 0.0087 conf: 1.0000
INFO [ecl/validation] val: -0.6478, lp: -0.0620 mean dev: 0.0080 RMS: 0.2147 conf: 1.0000
INFO [ecl/validation] val: 0.0436, lp: -0.0907 mean dev: 0.0294 RMS: 0.3506 conf: 1.0000
INFO [ecl/validation] val: -9.7967, lp: -9.8908 mean dev: 0.0672 RMS: 0.8262 conf: 1.0000
It break when I add cylinders as motors (base_link->fixed_joint->motor0) and then raise the rotors 1cm and change the revolute joints (motor0->revolute_joint->rotor0)
The IMU reads incorrect z-axis acceleration and I get those EKF errors. I can post my model.sdf but I was hitting the character limit for the post.
