ok so I have pixhawk2.1 cube with dragonlink mini rf module an serial mavlink telemetry, now Im able to connect to mission planner with ease, all information is werking, it doesnt matter on the MavLink protocol 1 or 2 or 57,000 or 19200…
But when I try and connect with QGC it lags and takes about a 90 seconds or so to connect, and when it does its missing all parameters, the odd thing is I hear the per-armed errors and saftey switch blah blah blah, but I get this error once connected …
“you are connected to a vehicle but did not return the full parameter list, as a result, the full set of vehicle setup options are not available”
now I can arm and dis-arm, but I do not trust this configuration like this. when I connect with USB I get full list of options.
Now the installed firmware came from mission planner 1.3.62 with installed ArduCopter 3.6.5
DragonLinkV3 firmware up to date.
Please help me make flight happen!
